ABS CAB HCU replacement
Old 09-30-2008, 07:16 PM
Woodchuck61's Avatar
What’s it all mean? The first part I think everyone knows, the CAB is Controller Anti Lock Brakes, the HCU is Hydraulic Control Unit.
My ABS CAB took a dump and when it did the HCU motor wouldn’t turn off even with the key out.
Replacing the CAB/HCU module ($400 + - retail) is very straightforward, 5 lines, two bolts and two connectors. The hard part is you need a DRB III to bleed the HCU and initialize the CAB. This turned out to be very easy once I found out how to do it (thanks to a friendly local Dodge Dealer mechanic). After the unit is installed you’ll need to go into the ABS menu then scroll down to Misc. and there are two options. You’ll need to get into both, the first is for bleeding the HCU and the second is set the pinion factor (tire size in revs per mile). Bleeding will need to be done twice, once before and once after bleeding the HCU.
fitzydog
21
10-11-2017 12:09 PM
oh boy
12-29-2008 07:02 PM
CTDinMT
09-02-2007 10:38 PM
mr T
02-24-2007 06:42 AM
Quick Reply: ABS CAB HCU replacement
