ABS and parkingbrake lights are on
Old Nov 2, 2004 | 01:03 PM
dIlLiGaF's Avatar
Angry ABS and parkingbrake lights are on
Both have been on for a couple of weeks now. I've replaced the abs sensor on the rear diff. because it was bad,did not fix the problem. That lead me to check the abs computer under the hold and low and behold it was bad. to confirm I replaced it with one I knew was working and that fixed the problem. So I really only have two questions.
1: Does anyone know if it's avaible anywhere else other then at the dealer, very pricey.
2: Since the new would have to be cailibrated I thought I'd have them enter the correct tire size. Unfortunately their computer does not go as high as a 315/75/r16 tire. Does anyone happen to know what the revolutins per mile is for this size tire? All the web sites I've checked did not have any information.
Old Nov 2, 2004 | 01:34 PM
BigBlue's Avatar
Have the dealer set the revs per mile for your tires at 599. That's what I had mine set at and it reads dead on. You might try looking at a junk yard for a the computer.
Old Nov 2, 2004 | 03:24 PM
HOHN's Avatar
Yeah, most 315 tires are 599-602 revs/mile
285s are typically about 625 rev/mile
stock 265s are about 652 rev/mile
Old Nov 3, 2004 | 10:05 AM
fitzydog's Avatar
Adjest your rear shoes and see how much play you have between them and the drums. My drums were so then that the shoes totally adjusted out barely touched the drums. I replaced the drums and the lights went off immediately. No definite but check this as it is easy to do. Take care. Aaron
Old Nov 3, 2004 | 10:23 AM
winkle's Avatar
Try this site for calculations.
http://www.dodgeram.org/tech/specs/axle/rpm_vs_mph.htm
Old Nov 3, 2004 | 10:54 AM
dIlLiGaF's Avatar
Thanks for all the replies guys, unfortunetlly it turns out to be the rear wheel abs controller. Is it a dealer only item or is there an aftermarket company producing such items out there somewhere?
Old Nov 3, 2004 | 07:25 PM
RATTLINRAM's Avatar
When I was looking for an aftermarket RWS sensor,,,,, I thought that either NAPA,,, AutoZone,,,,,, or AdvanceAuto websites listed the controllers, but no wheel speed sensors. You can check by going to their websites.
Old Nov 3, 2004 | 09:23 PM
fahrfrumwurkin5's Avatar
That's the exact same thing that happened to my '96 ram. Too many powerbrakes at the drag strip.
Old Nov 3, 2004 | 11:36 PM
ricter2's Avatar
have the same problem with mine,,,,2002 4x4 auto,,cummins,,,3500 series,,,4 whl.discs,,,,,tryed the new sensor at the rear housing,,,,nadda,,,,only 67 km on the truck so one wouldn't think it tio be the controller but i guess you never know do ya!!,,,,will give it a try,,,by the way,,,sensor is resonable,,,under $40. Cdn.
Old Nov 3, 2004 | 11:37 PM
ricter2's Avatar
lol,,,,67,000 km that is,,,,,oops eh,,,
quadstar
Nov 20, 2009 05:23 PM
polaris800sp
Nov 13, 2008 05:35 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
