99 CTD Missing Bad at Idle...
Old Jul 2, 2008 | 05:50 PM
JIT's Avatar
JIT
Last week the Injector Pump died. So I installed a New Rebuilt IP and a new LP. Bled injectors and Cleared the codes. Truck started fine but had a miss. I figured it was just air in the lines but after a couple days of driving it is still there.
The miss is very weird. Idleing in park it has a Bad Miss and the tach bounces between 900-1000rpm's. (also does this in neutral and when coasting in gear) But when idleing in Drive or Reverse (or when converter is engaged) It runs fine.
The weird part is NO CODES!
Truck is Stock with 189k miles.
Any ideas???
Thanks,
Josh
Old Jul 2, 2008 | 05:58 PM
scottsjeeprolet's Avatar
Recheck all the injector lines. Sounds like your getting air into one of the injectors.
Old Jul 2, 2008 | 08:46 PM
JIT's Avatar
JIT
I was thinking the same. Gonna replace the connector tube orings tomorrow and re-check the lines.
Old Jul 7, 2008 | 08:37 AM
JIT's Avatar
JIT
Rechecked everything and replace the orings. No leaks and it still runs like ****! I finally got a code though... P0216 Looks like this IP is bad!
Old Jul 7, 2008 | 09:54 AM
06RAM2500's Avatar
Probably a bad rebuild job. That totally sucks!
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
ouchman
May 29, 2005 01:18 PM
C Pierce
Mar 21, 2005 08:41 AM
GreenMachine5.0
Nov 27, 2003 10:45 AM
