98 stock 24 valve trans issue
Old 04-04-2007, 10:11 AM
heredia_mike's Avatar
a friend of mine request your help. his truck seems to be drop/slip into lower gears while at speed. he described it as "no torque loss just a slip into a lower gear then back". happens when he is just cruzing around running down the road. i did a search and found a few things, there is a possible ground issue with the PCM and a U joint vibration that causes the trans sensor to drop trans into lower gears. any other inputs are greatly appreciated.
thanks
Mike
Old 04-04-2007, 11:28 AM
Silverfox99's Avatar
is he sure its shifting down a gear?? or is it a slight increase in rpms that bounces back and forth here and there?
Old 04-04-2007, 12:59 PM
he discribed it as both actually. maybe 100 rpm and its done it at different speeds (35/60/45). thanks
Old 04-04-2007, 04:06 PM
Wolfeman's Avatar
Sounds like the torque converter locking and unlocking.Caused by electrical noise. Clean the battery terminals and ground connections under the passenger battery. do a search, many posts on this.
P.S, Bad batteries can also cause this.
Old 04-04-2007, 05:47 PM
thanks wolfeman. ill passed the info on. hope its a simple fix.
Old 04-04-2007, 09:59 PM
pdieselpu's Avatar
Could be the fuel filter as diesels are sooo dependant on fuel supply
Also air filter and tranny has to be solid
Old 04-04-2007, 10:46 PM
pdieselpu's Avatar
dan123dbl
02-13-2015 05:47 PM
1stTimeAround
07-09-2012 09:24 AM
12valve
03-11-2008 10:57 AM
DDysput
05-05-2004 07:44 AM
Quick Reply: 98 stock 24 valve trans issue
