92 rear main seal leak ???
Old 12-27-2007, 12:10 AM
rook440's Avatar
I just bought a 92 3/4 ton diesel with the getrag 5 speed ,It seems to have a leak around the rear main seal area (although I havent checked it out very well ) does anybody have any info on checking it or replacing it ???
On all of the forums I havent seen any info on this topic ....thanks
rook
Old 12-27-2007, 01:15 PM
turbos10's Avatar
The main seal is straight forward swap out. Get one at your local parts store and follow the directions to the letter. I used a Felpro and it worked great.
Old 12-27-2007, 07:54 PM
1stGen545's Avatar
Pull trans
pull clutch, flywheel and flywheel housing
you will see a plate that is bolted to the back of the block that holds the rear main
then remove the 4 bolts from the oil pan and 6 from the block that hold that plate on
Place plate on the table and knock the seal out.
Reinstall new seal and use the seal installer/depth tool that comes with the new seal from Cummins (not sure about the felpro)
clean all surfaces thoroughly and apply a thin coat of gray TRV to the mating surfaces and a small blob at the corner of the oil pan and block.
use the seal installation sleeve to install the seal over the rear of the crank
install and tighten all the bolts that were removed earlier ( pull block bolts up just till they contact the plate then tighten the ones in the oil pan then the ones on the block)
Reinstall flywheel housing, flywheel, clutch, and trans
Done 6 like this and no leaks so far.
Old 12-29-2007, 12:02 AM
rook440's Avatar
thanks guys ,,I will probably wait for warm weather to tackle it ,but its nice to know you dont have to pull the engine to change it ,,,,,thanks again
02dodge2500ctd
10-26-2008 01:39 PM
Nsomniac05
06-12-2008 07:11 PM
trik396
02-11-2007 02:21 AM
TXTad
01-17-2006 01:14 PM
robert chilton
09-10-2004 06:37 PM
Quick Reply: 92 rear main seal leak ???
