6spd trans rattle
Old 08-22-2003, 09:36 PM
BADodge2003's Avatar
6spd trans rattle
Recently I have notice a distinct rattle in the tranny, or drive line, going up and down through the gears. This is usually more prominent after the truck is warm. Especially after running 70-75mph for extended periods of time. It usually occurs the most from 2-3 and 3-4, and in the 12-1700 rpm range. Goes away around 1800 rpm. I mentioned it to the dealer when i was in to get the alternator bracket ordered, and he just flat shrugged it off. Quite frankly I am wondering why dealerships sell trucks they can't service? ??? Anyway. I am not exactly sure if it is in the tranny or somewhere else in the drive line. Anyone else experience something similar to this, or have any suggestions, I would greatly appriciate it.
Old 08-23-2003, 03:10 AM
RCW
RCW's Avatar
Re:6spd trans rattle
With your rattle being rpm specific, I suspect it is the preinjection cycle telegraphing though the shifter. There is a TSB on reflashing to correct that fluctuation and its associated noise. It may be found at WWW.dodgeram.org and follow the links.
Old 08-23-2003, 09:12 AM
Do you have any more specifics on that TSB, I was unable to locate it on that website. It is not listed under the 2003 DR section?
Old 08-23-2003, 08:41 PM
mymaur's Avatar
If it only rattles when you have your cruise engaged, it is probably the gas pedal. Alot of them seem to do it. If I just keep my toe under the pedal it stops. If the radio, or my wife, is turned up I don't here it at all.
Check it out.
Dodge has no fix
Old 08-23-2003, 10:57 PM
bulabula's Avatar
[quote author=RCW link=board=20;threadid=18745;start=0#msg175925 date=1061626238]
[/quote]I musta missed it too.
Old 08-24-2003, 05:34 PM
RCW
RCW's Avatar
I goofed, it is listed on my other service, and that is not available to the public.
See your dealer regarding a glitch in the preinjection cycle and a reflash to correct it from dropping out at mid-rpm levels. They will know to what I am referring.
kmltrucking101
11-21-2011 08:33 AM
westport
11-24-2005 01:43 AM
norsk
07-19-2005 08:26 PM
Steve034x4
15
08-13-2003 06:40 PM
Quick Reply: 6spd trans rattle
