2002 6spd Trans Rattle
Old Nov 21, 2011 | 12:14 AM
kmltrucking101's Avatar
Ive got a 02, 2500, 100,000 miles, 6spd trans. Last couple of days have noticed a "rattle" comming from what sounds like the transmission. Only occurs on cold starts (where the truck has been parked for several hours). Noise last only for 5 or 10 seconds then goes away. Truck runs out fine, shifts ok. Wanted some fast advice with the hopes of catching whatever this is before the truck lays down on me.
Thanks
Old Nov 21, 2011 | 05:49 AM
Copenhagenjunkie's Avatar
It's probably nothing if it lasts that short of time.
Old Nov 21, 2011 | 07:23 AM
dieselwill's Avatar
check fluid level/condition, these need regular service to live.
Old Nov 21, 2011 | 07:30 AM
MikeyB's Avatar
Does the rattle stop if you push the clutch in? If so most likely it's the clutch. My clutch does it sometimes, mostly on really cold mornings.
MikeyB
Old Nov 21, 2011 | 08:33 AM
Scotty's Avatar
Top's Younger Twin
I would get it checked and serviced. I did not do this with my 01. Luckily I was still under warranty. I lost 6th gear in -40 weather...the chatter initially was thought to be the clutch...put a Con FE in anyway after that. Once the cold weather hit again...the chatter returned and then would go away. The dealer told me that the synchros were bad and pieces started to come loose and eventually I lost 6th. Disclaimer; This is what the dealer told me.
westport
Nov 24, 2005 01:43 AM
norsk
Jul 19, 2005 08:26 PM
CStroked
Jul 7, 2005 10:55 AM
BADodge2003
Aug 24, 2003 05:34 PM
latitud_rt
Mar 11, 2003 04:51 PM
