6spd shifting probs
Old 12-02-2003, 07:17 AM
Muted User
Superduty12v's Avatar
6spd shifting probs
I was wondering if anyone knew if the 6spds had synchros for the reverse gear? My 6spd is having some really rough notchy shifting and I think it's due to the clutch not fully disengaging because of a older slave cyl. (1996) I think since the slave cyl is older it's not pushing the slave pushrod out enough and not disengaging the clutch completely. Sometimes if I try to go right into reverse when the truck is standing dead still it will grind. If reverse doesn't have a synchro than to me that can only mean the clutch isn't disengagin all the way. With the rest of the gears it's hard to tell becuse it could be the synchros them selves causing the problem. A new slave cyl is $384 bucks from dodge so I'm trying to get this right the first time. I have already changed the tranny fluid 3 different times using dodge fluid and aftermarket so I know it's not that type of fluid I'm using. I have the factory fluid in it right now though. All 3 times I changed the fluid I had a fair amounbt of brass shavings from the synchros floating in the fluid. So I'm just trying to save what synchros are left for the winter so this summer I can put new synchros in when it's nice and warm. Any suggestions ideas would be great. I don't think it makes a difference but I'm using a slave cyl that was on a 5spd tranny. I'm pretty sure all the slaves are the same though so I doubt that's important. Thanks in advance.
-Anthony
Old 12-02-2003, 05:00 PM
thumper 549's Avatar
Re:6spd shifting probs
i'd go back to the draging clutch thought
bnold
11-01-2006 10:09 PM
westport
11-24-2005 01:43 AM
norsk
07-19-2005 08:26 PM
7mmrum
10-20-2004 08:16 PM
Superduty12v
12-02-2003 11:55 AM
Quick Reply: 6spd shifting probs
