6inch lift??
Old Jun 4, 2008 | 09:51 AM
willy312221's Avatar
6inch lift??
I'm putting on a 6inch BDS lift and wanted to know, if there is any troubles with them or getting it on that i would like to know? Thanks for the input. gotta 04 standard cab
Old Jun 4, 2008 | 02:09 PM
dbossdiesel's Avatar
Just a few things! You might need to get new lower control arm bolts in the front! The cam ones! I tried to take mine out for a lift and they where frozen in the bushing and I need to cut them! Also, I've heard from alot of forum users the pitman arm is a bi-och to take off even with a puller! I've even read that they have broken pullers and desroyed steering boxes! Either way good luck sir!
Old Jun 5, 2008 | 01:00 PM
i will keep that in mind when i go puting it on. thanks for the info.
Old Jun 5, 2008 | 04:51 PM
Hey no problem! Little help goes a long way!
Old Jun 10, 2008 | 05:53 PM
nate4567's Avatar
I just put a 6" lift on mine and had to cut the pitman arm of with a recip saw. I tried to heat it, beat it nothing worked so since I had a new one I cut it down the side, got it glowing hot and cooled it with cold water and they did the trick finally. That is 2 that I have had to take off that way. But you torch them to 225lbs, so that is problay why
Good luck
nathan
Old Jun 10, 2008 | 06:40 PM
Is there any other problems i might run into? Like adding brake lines,transfer dop kit ect. I have never put one on and wanted all the advice i could get. Thanks
Old Jun 10, 2008 | 09:33 PM
nate4567's Avatar
I have heard that you might need a transfer case reindexing ring. basically it will lower your front driveline angle by twisting the transfer case like 30 degrees. The only way to see if you need it is to see if it grinds when you take off for the first time. They are about 250 - 300 dollars, that is about all that i can think of.
Good luck
nathan
Old Jun 11, 2008 | 06:13 AM
Thanks for the info! hopefully i won't need one
Old Jun 11, 2008 | 09:48 AM
XLR8R's Avatar
With a true 6" lift, I don't see how you can get away w/o an indexing ring and still have enough caster in the axle.
Old Jun 11, 2008 | 10:45 AM
I know I will be putting 4inch block in rear so is that a tru 6inch lift
Old Jun 11, 2008 | 10:58 AM
dodgediesel's Avatar
Got a BDS on my '07 with no issues at all!! Do the long arm kit to make the ride even better... ProComp now makes a true 6" kit but my BDS kit rocks.
I did put in the BDS transfer case drop bracket but took it out because it did all kinds of stupid things due to the angle drop of the engine, tranny and transfer case. The clocking ring from Superlift would be the way to go if you have issues but I don't....
Old Jun 11, 2008 | 08:50 PM
dodgediesel do you have any pics of your lifted truck?
Old Jun 11, 2008 | 11:48 PM
I'm getting my 20's and 37's on Friday. I will post some new pictures but here's a current one now with 17's and 37" BFG Mud Terrains..
Old Jun 13, 2008 | 10:27 PM
checkster's Avatar
Have fun with the upper passenger side control arm frame bolt. Had to drop my whole exhaust to get it out. 1 bolt, 3 hours
Old Jun 13, 2008 | 10:57 PM
XLR8R's Avatar
Yeah - that's just retarded!
Installing adjustable control arms this month - gonna try real hard to figure out a better way around that dang bolt!
