3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
6.7L flexplate on a 5.9L
Old Feb 9, 2009 | 02:25 PM
LFD2037's Avatar
Will the 6.7 flexplate bolt to a 5.9? I heard they were alot stouter & only $120 from the dealership. TIA
Old Feb 9, 2009 | 04:57 PM
Stovetop535's Avatar
I called and was talking with Dusty at HTS today and he said he had not gotten one in to look at yet. I am also curious if they will bolt on....
Old Feb 9, 2009 | 05:42 PM
LFD2037's Avatar
I know some of the 2nd Gen. guys have done it. Is it still the same crank? I think that would be the main factor. My dealer has the 6.7L for $171 & the puny 5.9L for $460!!!
Old Feb 9, 2009 | 06:40 PM
cbrahs's Avatar
if you have it out, you might as well put in a stronger sfi approved one.
Old Feb 9, 2009 | 07:32 PM
LFD2037's Avatar
Dealership rebuilt tranny 10K mi ago, under warranty, & didn't lock-tite TC bolts. Needless to say they came loose & did some damage. Now they are gonna repair a few things free of charge so I was gonna have them use a 6.7L if it will fit. Otherwise, I'd be going w/the black BD flexplate. Anyone w/a for sure answer on the fitment?
Old Feb 10, 2009 | 09:01 AM
LFD2037's Avatar
I called the dealership & of course they have no idea if they are interchangable. How could I go about getting an answer to this ASAP?
Old Feb 10, 2009 | 11:49 AM
Justice4all's Avatar
Compare the two parts side by side. Take some measurements.
Old Feb 10, 2009 | 12:45 PM
LFD2037's Avatar
Problem w/that is I don't have either part in hand & neither does the dealership.
Old Feb 10, 2009 | 03:06 PM
XLR8R's Avatar
They shouldn't be special order - anything the dealer doesn't stock usually shows up first thing next morning... have them get both & compare at the counter if you know what you're looking for.
Old Feb 10, 2009 | 04:09 PM
LFD2037's Avatar
Since it's on their dime, I doubt they would be game.
Old Feb 12, 2009 | 08:51 AM
LFD2037's Avatar
Mechanic @ dealership said it's a direct fit & if it's messed up they will put the 6.7L flexplate on there!
Old Feb 12, 2009 | 08:58 AM
yelloz28's Avatar
How much thicker or "stouter" are the 6.7 plates?
Old Feb 12, 2009 | 09:49 AM
LFD2037's Avatar
He said about 3 times more durable & about .085" thick. They don't have all of the cut-outs that the 5.9 has. Here's a pic of one.
https://www.dieseltruckresource.com/...=227137&page=2
Old Feb 12, 2009 | 10:13 AM
kantdrive55's Avatar
DTR Advertiser
We have a stock one and ours here to do some testing with. We have it mounted to the back of the motor out of a truck so measuring should be easy. I will let you guys know as soon as I have the measurements.
Old Feb 13, 2009 | 12:51 PM
DTR Advertiser
Well after some research and measuring it turns out that the 6.7 uses a different bolt than the 5.9 version. Now the center portion of it isn't exactly the same which can allow the torque converter to not be centered which can cause a vibration that would take out the pump on the transmission.
