518 to getrag swap
Old 01-04-2010, 05:58 PM
Falcon1's Avatar
518 to getrag swap
I found one with transfer case complete I found clutch peddle assembly I found a flywheel all I need is a clutch. Any thing else I need to know before I swap. Will the auto crossmember work? Will I need to have work done on the drivelines?
Greg
Old 01-04-2010, 11:07 PM
Firstgenfanatic's Avatar
Greg
Nice to see that you located a manual transmission. This should be an excellent upgrade. Good luck!
Old 01-05-2010, 08:36 AM
EClancy's Avatar
i had to swap both driveshafts over to the 5spd d-shafts
Old 01-05-2010, 08:55 AM
Falcon1's Avatar
That's what I'm wondering, if it needed to be done.
Old 01-06-2010, 08:31 PM
Falcon1's Avatar
Will I have to swap out the cross member? Do I need to drill new holes? How did you hook up the clutch safety switch? Anyone out there that has done this I could use some info or is it a big secret?
Old 01-06-2010, 08:43 PM
Anyone out there that has done this I could use some info or is it a bid secrete?
Must be secret squirrel stuff............
Old 01-06-2010, 09:12 PM
EClancy's Avatar
i do not have a clutch saftey switch...dont need one. you do have to make the truck "think" its in park though
Old 01-06-2010, 09:42 PM
Falcon1's Avatar
So what did you do???????????????/
geeezee it's like pulling teeth
shaunbolton
04-14-2012 11:21 AM
andyt
02-26-2010 07:01 PM
Bookshelf
01-20-2009 02:03 PM
scottmn1
04-28-2006 03:26 PM
Quick Reply: 518 to getrag swap
