4X4 launch
Old Feb 27, 2010 | 12:43 PM
mccallsc's Avatar
4X4 launch
When I try and do a four wheel drive launch I can't build more than 10 psi before it feels like the engine starts to sputter. What could be the problem or is it normal?
Old Feb 27, 2010 | 01:16 PM
wurkenman's Avatar
With an auto in your truck, you won't be able to do a boosted launch without a BD RAD. The torque sensing defueling takes over without it. Basically what is happening is your computer is sensing increased RPM's and no wheel movement so it shuts down your fuel to prevent damage (they call this torque management). The engineers are always looking for new ways to help us.
Old Feb 28, 2010 | 06:10 PM
Dinner's Avatar
Just like Wurkeman has mentioned, it is Torque management acting up on you. Smarty will help get rid of most of it, however a BD RAD will eliminate it entirely when on.
Old Feb 28, 2010 | 08:57 PM
DodgenIt's Avatar
http://www.dieselperformance.com/ind...duct/index/43P
This is what you need/ what is mentioned above.
Believe me, it does the job. I noticed a big differance off the line once I got my RAD hooked up.
I dont race without it.
Old Mar 1, 2010 | 07:45 AM
RowJ's Avatar
Yup, The BD RAD works well. (Now called the Speed Controller, I believe). Also allows higher top speed!
And a fairly simple install.
Be aware you lose RPM and oil pressure gauges when it is turned on.... and it will throw a code after you turn it off, for the next 3 starts.
But for Drag racing, it is a must have... especially if you will be going to bigger injector.
RJ
V.R.Wheeler
Aug 4, 2007 01:00 PM
Big Dblue
16
Apr 30, 2007 08:37 AM
Big Blue24
Feb 7, 2007 08:03 AM
rippit
Feb 6, 2007 01:23 PM
GEN3TRQMONSTER
Oct 26, 2006 12:19 PM
