48RE Trans trouble
Old May 24, 2012 | 07:01 PM
TKC2000's Avatar
48RE Trans trouble
The trans seems to be "stuck" in drive. Meaning, I can shift the gear selector to the different positions with no problems. The truck drives normal for the most part. No fluid has leaked and the level seems good and in good shape. There is no grinding or binding or banging. When I select Neutral the truck is still in gear, it still drives forward. When I select Reverse it rolls/drives (just a couple inches) into it then stops. I select Park and it does the same thing as Reverse. I can run thru the gears manually, D1, D2, D, and all seems OK. I haven't done any road testing with it since this started happening, just up and down the street in front of the house. It's a Garmon built trans with billet input shaft, laminated flex plate, upgraded VB and triple disk TC. The truck has 152K miles, the trans has 50K of that but not sure exactly since I bought it from a friend with a salvaged truck, but I don't think it had too many miles on it then.
I need to get this figured out soon. I was planning a trip up to Morgantown, WV and seeing some friends in MD.
Old May 24, 2012 | 10:42 PM
bentwrench97351's Avatar
may be a broken reverse band
ridlangus123
Dec 30, 2013 08:36 PM
2500Ram
May 18, 2010 12:55 PM
HERC FE
Nov 24, 2008 08:16 AM
workingdog
Feb 21, 2008 07:04 PM
boehunter49
Dec 4, 2002 05:57 PM
