3K GSK install
Old 12-01-2003, 01:44 PM
CountryDiesel's Avatar
3K GSK install
It has been suggested that I install a 3K governor kit to allow the engine to exceed the 2700RPM defuelling cutoff.
How hard is it to install this kit? Special tools?
David
Old 12-01-2003, 03:02 PM
Got Smoke?'s Avatar
Re:3K GSK install
It's relatively easy to install. I would suggest using the side plug on the pump. What becomes a pain then is removing the fuel shut off solenoid, but with patience(sp) it will come.
You can remove the retainer nut on the springs with a screw driver, but I highly recommend grinding a notch in something like a screwdriver or small prybar(what I used) to fit the notches in the retainer nut and clear the stud for the gov. springs.
You will love this BOMB it was my first. Really helped me towing gooseneck's with 33" tires and 3.55 gears.
siebertl
06-10-2007 02:29 PM
SHARPMACHINE
03-06-2007 08:45 AM
plow
08-09-2005 04:25 PM
MR HYDROSEED
03-09-2005 10:49 PM
Got Smoke?
10-26-2004 03:57 PM
Quick Reply: 3K GSK install
