3GSK problems
Old 01-18-2010, 04:21 PM
97dodgeram2500's Avatar
3GSK problems
so i had the 3gsk installed by tim alomost a year ago, he put a new tranny in for me back in july, ever since then the truck will only pull to 2700 rpms before the tranny swap it would pull all the way to 3000 rpm's, so what can i do to turn it back up? another ? is i'm thinkin bout doin the hd valve springs and goin up to 4gsk does anyone know where i can find just the springs to add into the 3gsk or do i have to buy the entire kit again? thanks
Old 01-19-2010, 01:45 AM
Tate's Avatar
It would likely be due to the shift points. Talk to your tranny guy about moving those up. If you switch to a 4k, and it is your tranny holding you back, you won't see much change.
Old 01-19-2010, 03:44 PM
i talked to tim who did the tranny when i went to pick up the truck and he said he set up the shift points up to 24v shift points, but he said the tranny wouldnt have anything to do with the 3gsk changin
Old 01-19-2010, 03:47 PM
Tate's Avatar
Well, if the tranny always shifts at 2700 rpm, you're not gonna get passed that unless you are manually holding it in that gear. Is that what you're doing?
Old 01-19-2010, 05:08 PM
West Coast's Avatar
Sounds like you need a new tranny guy.......
Old 01-19-2010, 09:06 PM
it will hold 2700 all day long in the same gear til u need to shift just wont go past 2700
Old 01-21-2010, 10:54 AM
sgreen3's Avatar
You get the springs from cummins, and it sounds like a tranny issue, Maybe try turnin the springs a tad more, to see if you get any more RPM
Old 01-24-2010, 11:56 AM
wvopowered's Avatar
about the 4k spring when I bought mine from Source here in portland I was going to just get a 3k .But I saw them removing a spring from the kit and ask about it they only have the 4k and just remove the one spring set for the 3k kits.You could call them or check with a shop closer to you. I put in the 4k set up and it really will not go past 3500 unless you hold it there for a long time that is probably due to my timing and fuel delivery also.
So if you put it 1st gear manually you are saying it will not rev past 2700.If that is correct you and you have good power up to that point I would think it is the springs but it could be fuel also might want to check fuel pressure or fuel filter. Will it free rev to 3k? if so it is could be a fuel problem
Old 01-24-2010, 02:32 PM
rebal's Avatar
when he installed the trans did he put a tighter converter in ? try and manually hold it in gear and see if it will rev past 2700 . it could be the gov springs are to tight also 1 click on the springs can make a big differance
Old 01-25-2010, 05:45 PM
yes the conveter is a triple disk if i hold it in first gear manually it will go to 3000
Old 01-25-2010, 10:12 PM
Tate's Avatar
Tranny shift points then, talk to your tranny guy, or get a guy that will change them.
pappyman
35
06-26-2005 12:22 AM
wtmtnterror
04-07-2005 03:24 PM
wtmtnterror
04-06-2005 09:18 PM
crossy
03-28-2005 05:12 PM
crossy
03-20-2005 09:03 AM
Quick Reply: 3GSK problems
