370s help
Old May 6, 2009 | 09:36 PM
1bad93's Avatar
370s help
well im going to get a set of 370s im pretty sure and i want to know if i keep my pump close to stock can i run a stock turbo with them just driving around? cause im 16 i cant afforde a 1500 dollar turbo any time soon. and i was between two companys farm boy diesel and coaltrains who do yous like best?
any help would be awsome cause i would really like to know if i need to hold off or go a diffrent route on injectors.
Old May 6, 2009 | 09:51 PM
peobryant's Avatar
Yes you can run 370's with the stock turbo just puttering around, but I hope you already have gauges (didn't look at sig.) With stock pump settings, it shouldn't get to hot.
I'm not sure about either of those companys, but I know people with New Era 370's absolutely love them.
I went the cheap route, and bought 2nd gen 370's and had the nozzles put on my 1st gen injector bodies.
Old May 6, 2009 | 09:54 PM
1bad93's Avatar
well ok thanks. and yea i got gauges.
Old May 6, 2009 | 09:57 PM
peobryant's Avatar
Make sure they know the injectors are for a 1st Gen. The spray patterns are different between 1st and 2nd gens.
Old May 7, 2009 | 12:14 PM
1bad93's Avatar
ok yea i know.
Old May 7, 2009 | 05:36 PM
archer39's Avatar
you will be fine with the stock turbo. You could tow with them just fine also.
Old May 7, 2009 | 05:50 PM
1bad93's Avatar
thats sweet. was kinda afraid of putting that size injector on with the stock turbo. and how do you like your coaltrain injectors?
Old May 7, 2009 | 05:53 PM
peobryant's Avatar
With mild pump tuning, your stock turbo will be fine. Don't go crazy though.
Old May 7, 2009 | 05:57 PM
1bad93's Avatar
well i have my smoke screw bottomed out and my afc is one turn from bottomed out but my full pwer scew is in the stock location. is that too much
Old May 7, 2009 | 05:58 PM
peobryant's Avatar
The fuel screw is all you really need to worry about. So if it is in the stock location, yep, it's fine.
Old May 7, 2009 | 06:31 PM
archer39's Avatar
my injectors seem to work just fine.
I went crazy and it seems just fine... Its all about controlling your right foot.
Old May 7, 2009 | 07:36 PM
You should get these 370's by sat. night so you can show off with smoke in the show n shine at the buck!!
Old May 7, 2009 | 09:22 PM
1bad93's Avatar
yea wish i still have to get some money but i think i should have a set in the near future.
well i think i leave the power screw alone till i get a better turbo dont feel like frying the poor little h1c.
Old May 7, 2009 | 09:24 PM
1bad93's Avatar
hows the egts with just the h1c upgrade?
Old May 7, 2009 | 09:33 PM
peobryant's Avatar
Just driving around, you wouldn't have to worry about EGT's. When you are towing is when you really have to keep an eye on them.
My advice is, after you install the injectors, take the truck for a spin, and get some baseline numbers. After that, start tweaking the pump until the EGT's get out of hand. Then back it off a little bit.
