305 Nittos On Stock 2500 w/ 5th Wheel RV
Old 05-16-2009, 03:39 PM
TitansFan's Avatar
I really love the look of the 305 Nittos Terra Grapplers and want to get some for my Ram to use with the stock rims. I wanted to know about the tires rubbing...specifically when I have a load in the bed. We have a 5th wheel RV that has a hitch weight of 1775 lbs. Do you think I can use these tires? I've thought about installing air bags to help out the rear springs. A local tire store has the 305s for $259 each.
Thanks!
TitansFan
Old 05-16-2009, 04:16 PM
rbreak's Avatar
I don't see why you couldn't. I have those tires on stock rims on my '07 qc long bed 4x4 CTD 2500, and with a bed full of tool box, coolers, a generator, fuel, camping gear, and a 700lb atv, plus a tag along camper with a hitch weight somewhere around 750~900lbs, I have no problems at all. I do have airbags, but I only run 10~20psi in them, I don't think the truck really even needs them. I like the tires. I haven't had them long enough to comment on tread life, but when I tow or haul I run 60psi and they ride great, and around 40psi unloaded and they are still pretty smooth (especially for an e-rated tire). They don't bulge at all (e-rated) and there is no sidewall sway (that I can feel anyway). They aren't major mud tires, but they still get decent traction. I have hauled my camper through some muddy fields and dirt roads to get to some of the camping/riding areas, and in 4 low, they pulled right through some pretty nasty stuff. They also ride great on the road. Unless something really bad happens with these tires like a tread separation or something (I doubt that will happen), I will replace these with another set when they wear out.
Old 05-16-2009, 04:29 PM
yellowhemi's Avatar
I have put 2500 lbs in my bed and absolutely no rubbing issues at all.
Old 05-17-2009, 08:12 PM
texasaggie2005's Avatar
Check my thread out in this forum called "new tire pictures...". No rubbing issues at all.
Old 05-17-2009, 08:16 PM
Ghostrider304's Avatar
I have them on mine with a leveling kit. No problems what so ever. They even ride nice.
Will-
Old 05-17-2009, 08:19 PM
tt433's Avatar
I have an 04.5 3500drw i got 305s on it i love them no tow problem i tow a 35 foot fifth wheel over 15000 lbs no problem.
Old 05-18-2009, 08:16 PM
TitansFan's Avatar
Sounds like the 305s will work just fine.
Old 11-16-2011, 11:21 AM
Randy R's Avatar
305 17 Nittos
Thanks!
TitansFan
Hello I Have a 2011 2500 that I just installed 305 70 17 Nittos. I'm in the RV business.. Check out my pics on Facebook Johns RV. I've had no problems with tire rubbing with theses tires. I love them, very smooth and makes my truck look awesome
ZeroTolerance
07-06-2011 02:18 PM
checkster
10-04-2009 10:43 AM
hotdram
11-04-2003 03:10 PM
dsljunkie
08-11-2003 12:08 PM
Quick Reply: 305 Nittos On Stock 2500 w/ 5th Wheel RV
