300 to 370 injectors
Old Apr 10, 2003 | 10:23 PM
dodgeman01's Avatar
I started out with the 300 injectors a year and a 1/2 ago. Just for my information and a good deal I bought a set of 370's. Today I installed them, and Here is what I have to say.<br><br>I was expecting a big difference in the switch but I can't really feel one. My EGT's are up some not much. My truck smokes less than before &quot;Keep in minde I only changed the injectors and nothing else&quot; I might have gained 10-20hp &quot;MAYBE&quot;. The biggest difference is turbo lag. I can really feel a difference in how fast my turbo spools up. It is a lot faster than when I had the 300's.<br>Are they worth the extra money if you already have the 300's? I think not.<br>DM01
Old Apr 11, 2003 | 09:52 AM
98rammer's Avatar
Re:300 to 370 injectors
what about the 300s? i just put some 215's in an notice a little difference, but nothing drastic (which i expected). are the 300's for sale? 8)<br><br>Tom
Old Apr 11, 2003 | 11:32 AM
vssman's Avatar
Tom,
I replaced my stockers (180's) for the 300's last November and it made a huge difference in power. Next time I see you at one of the NETDP meetings we'll go for a ride.
Paul
Old Apr 11, 2003 | 11:43 AM
dodgeman01's Avatar
Sorry but a guy offered me 300$ for my 300's and I only pais 3704 for my 370's so I could not pass up the deal.
As posted before I saw a big difference between the 180hp and the 300's. I just think that all that bad press that the 300's get is wrong. They may not burn lthe fuel like the 370's but as in HP they don't add that much if any. What I'm trying to say is that if you find a set of 300's for a ggod price they will work out just like the 370's.
I don't know how they will effect my MPG's but I will be doing a test here soon to see how they help/hurt.
DM101 class is over for today.
Old Apr 11, 2003 | 07:11 PM
98rammer's Avatar
[quote author=vssman link=board=16;threadid=13470;start=0#126981 date=1050078750]<br>Tom,<br><br>I replaced my stockers (180's) for the 300's last November and it made a huge difference in power. Next time I see you at one of the NETDP meetings we'll go for a ride.<br><br>Paul<br>[/quote]<br><br>alright paul will you be going to the dyno day?<br><br>aaron: that's first to me. i always thought that the 300's and 370's gave a failry good difference....although i know about the smoke issue. i haven't driven/ridden in a truck with those injectors though. hmm...we'll see what the future holds (maybe i'll just do the turbo and big injectors from like DD at once after the tranny gets done)....<br><br>my 215's run smoother at idle with a different tone. spool seems to be a little slower (even after playing around with the AFC- which never ends with me). pegged my EGT guage the first time tonight. i guess i should have honestly gotten 300's or higher for the dyno as i can always pull my plate back.<br><br>Tom
Old Apr 14, 2003 | 09:13 AM
dodgeman01's Avatar
One other thing I noticed is that after putting the 370 injectors in My truck is really jumppy under 2krpm. At firrst I figured it was me foot moveing the pedal. Not so. If I'm driving down the road and hit a nice sized bump the truck will start to jump. This is no little rocking motion. It is a jerky neck breaker. I thought that at first I could just either let off the go pedal or mash it and it would go away. If I let off the pedal it stops, if I push it the jerking will continue until 1900 and it will easy up until it stops.<br>Any Ideas as to why this is happening? Never hapend with my 300's<br>DM01
Old Apr 14, 2003 | 09:34 AM
rharveysr's Avatar
Do you have to change out the delivery valves when you use the 370's with the 180 hp pumps??? I have heard that its a good idea to change to 191 delivery valves because of this situation..<br> I may have went down a rabbit trail...<br><br>Rick
Old Apr 14, 2003 | 11:42 AM
vssman's Avatar
Rick,<br><br>I believe the delivery valves on the 180 pump will work with the 370's. I'm pretty sure you need to change the DV's if you have a 160 pump.
Old Apr 14, 2003 | 11:51 AM
dodgeman01's Avatar
I have the 180hp pump.<br>DM01
Old Apr 14, 2003 | 12:11 PM
yrusoslow2's Avatar
I have the 175 HP pump with 370's and I have not noticed a problem. As far as the jerking motion when you hit a bump, I do have that problem. I don't know if it is because of the injectors or not. I never really thought of that but I think I will look into that. I do plan on putting the 191 DV in as soon as I can afford them. So much to do so little money.
Old Apr 14, 2003 | 01:51 PM
rharveysr's Avatar
Lets throw something else into it...could the return springs on the throttle linkage be weak and right foot be causing the problem. <br> I had this problem of bucking when I hit a bump and pulling my 5er. I talk to DC and they said that yes there was a service bulletin on this very problem. But being the nice people they are wanted to charge me $200 to replace the springs and a couple of other items.<br> I decided to go down and get a package of generic springs and matched the springs length but a strong spring..solved the problem for about $7...<br>This fix would be cheaper than dv's..<br><br>Rick
Old Apr 14, 2003 | 10:19 PM
dodgeman01's Avatar
I already have a different set of springs because I did not like the stock ones.<br>DM01
Old Apr 15, 2003 | 03:29 AM
VinDiesel's Avatar
From what I have gathered (who I have talked to), the bad rep on the 300s is unfounded. In fact, they have a BETTER pattern than the 370s, they just don't dribble in as much fuel.<br><br>Since installing 370s in mine, the engine runs considerably rougher when cold. Boost took a huge jump. Too much, but I turned my boost controller down. [Some of that is because of the hybrid and 12cm2 housing.]
Old Apr 15, 2003 | 08:04 AM
Smokee's Avatar
<br><br>I have a 160 pump and 370's. Works fine. I second the idea about the throttle springs and the bumps
northslope
Feb 22, 2005 07:59 PM
northslope
Feb 22, 2005 04:50 PM
JCamper
May 15, 2003 09:30 PM
R-O-B
15
Oct 31, 2002 11:49 PM
