285s or 305s
Old 03-28-2007, 07:34 PM
wreedCTD's Avatar
285s or 305s
I need help deciding which tires to get. I am going to keep the stock wheels for now but one day i might get some wheels. I am not going to do any kind of lift. I am either going to get the BFGs or Toyos but i cant decide on 285s or 305s.
What do you guys think?
Will the 305s rub?
Will either size tire rub if i get wheels with no lift?
Which tires are easier to balance the Bfgs or Toyos?
Ill post more questions as i think of them.
Thanks!
Old 03-28-2007, 07:36 PM
Black SunShine 04's Avatar
The 305's will do you just right trust me. I have 315's on my stock wheels with just a leveling kit and no rubbing. Have a good one.
Old 03-28-2007, 07:38 PM
wreedCTD's Avatar
oh and another question is the 305s are not rated for the stock wheel width. How do all you guys get away with them on the stock wheel?
Old 03-28-2007, 07:41 PM
It will fit and be ok it just pulls the sidewalls a little,you just have to keep them rotated. ♣
Old 03-28-2007, 07:45 PM
wreedCTD's Avatar
how much if any with the 33s raise the truck? i am a tight fit already in my parking garage at work.
Old 03-28-2007, 07:50 PM
I have a standard garage door 7' or so and my truck still fits with the 315's so you'll be ok.
Old 03-29-2007, 11:52 AM
nitis's Avatar
pending on which tire you speak of 305s and 285s are the same heighth at least in BFGs they are only diff is the 305s are wider and have the infamouse E stamped on them if you use the stock rims I would go with 285s
Old 03-29-2007, 11:57 AM
dodgezilla04's Avatar
i have the toyo 295's. no lift. they do rub only on the right side. it fits under a 7' garage door by about 1".
Old 03-29-2007, 12:59 PM
koogala's Avatar
Man I hate to hear that! That is the EXACT tire I wanted. How bad is the rubbing? Everybody else has said that 295's wouldn't rub. Is it tolerable?
Where do they hit?
Old 03-29-2007, 02:13 PM
surfram's Avatar
Dodgezilla04, what is the backspacing of your rims? The 295s should not rub on stock rims. Aftermarket rims with less backspacing move the tires away from the control arms but too little backspacing will rub the fender lining.
Old 03-29-2007, 02:22 PM
abc4yew's Avatar
Depends what you want to do with the tire....Toyo now has a 285 75 17 which is about 34 inches high....taller than a 305 70 but more suitable for your rims. Matching the tires and rims to the manufacturers specs for the tires always gives you a better ride and tire wear regardless of what anyone will tell. ks
Old 03-30-2007, 09:50 AM
mine only rubs the right mudflap when backing to the right with the wheel hard over. 99.99999% of the time, no rubbing.
i dont know what my backspacing is, have to go home and measure for you. and i am hesitant to install a leveling kit, cause it wont fit under the door then.
Old 03-31-2007, 05:57 AM
own1bigtruck's Avatar
I have 305 Pro-Comp Extreme AT's on stock rims on mine and have had no problems with it yet. Love these tires, much improved over the stock BFG's that was on it
labreck
07-31-2007 12:38 AM
wreedCTD
19
05-08-2007 11:16 PM
VikingDiesel
15
09-07-2006 12:45 PM
ratsun
10-03-2004 10:38 PM
ARAcummins
07-18-2003 12:34 PM
Quick Reply: 285s or 305s
