285/70/17's.......How Much Spacer?
Old 06-07-2007, 10:12 AM
Rollin' Smoke's Avatar
how much of a rear spacer would I have to run to get these on the rear of my dually? dont think the front will have a problem but i want to be sure for the rear. thanks alot
Old 06-07-2007, 10:22 AM
Box5's Avatar
i've been looking into some taller tires, but keep hearing that running a spacer isn't smart when towing, so duallys are limited if ur gonna tow with it. Hopefully i'm wrong because I want taller tires to gear my truck more like 3.55's but nobody seems to have much info on this topic.
Old 06-07-2007, 10:28 AM
yea i have been looking into the same thing. but you really cant find a much taller tire than the stockers. i also want the taller tire for the gearing help. this would drop the RPM's at highway speeds and keep it more under the 2k RPM range better.
Old 06-07-2007, 10:32 AM
Box5's Avatar
the only tire I found with a 35x10.50 was Super Swapper SSR-41R, lol. They have a pretty high load rating, it's actually more than most E rated tires, but i'm worried they would wear pretty fast. u could run those without a spacer or anything. and run wider tires up front.
here' they are
http://www.intercotire.com/site34.php
Old 06-07-2007, 10:35 AM
yea i have always seen people with swampers wear them out pretty quick.
and those suckers can get expensive really quick. i have been looking into alot of the Cooper Tires. they seem to have a good selection of 17" tires and quit a few options for tread design
Old 06-07-2007, 10:36 AM
metalbasher's Avatar
I just took a set of 285 70R17 BFG AT's off my truck to put on some Rickson's. It took a 1/4 inch spacer in the back for the tires not to rub. Ran the truck with a 3500 pound slide in camper and no rubbing. If your just towing I don't see a safety issue with a small spacer.
Old 06-07-2007, 10:38 AM
Box5's Avatar
Also these, but they are 6 ply and aren't rated for much wieght
http://www.intercotire.com/site32.php
thats great news cause i have some 1/4" spacer sitting in a box in my garage. i have never heard of Rickson's, you have anymore info on them?
Old 06-07-2007, 10:40 AM
Box5's Avatar
http://www.ricksontruck.com/
If u have 4.10's, how much would 33's drop the rpms?
which ones are you referring too?
Old 06-07-2007, 10:43 AM
well check this out and play around with it.....
http://www.discounttire.com/dtcs/infoTireMath.dos
Old 06-07-2007, 10:44 AM
Box5's Avatar
the SS narrow ones ^.
That rickson website has a calculator to do gearing, and with 33's on my truck it would be like having 3.64 gears. With 35's it would be like having 3.43 gears.
http://www.ricksontruck.com/calculators.html
Old 06-07-2007, 10:46 AM
thats should help drop the rpm when cruising down the highway and help the mileage out some.......or at least let you go a little faster and retain the same mileage since you can go faster with less rpm
Old 06-07-2007, 10:48 AM
Rickson makes 19.5'' wheels for light trucks. Usually 19.5's are only for medium duty trucks like a 5 ton. I have 245 70G19.5 tires on my truck now, there 33.5'' tall, 14 ply and theres plenty of room to go with taller tires in the future with no rubbing/spacer issues.
Old 06-07-2007, 10:49 AM
Box5's Avatar
but how much are the 19.5" wheels and tires?
If I can find some 265/85/16 that would equate to 33's, with 10.4 width so they wouldn't rub on the duallys even without spacers if i'm correct.
Quick Reply: 285/70/17's.......How Much Spacer?
