20's Tire Options
20's Tire Options
I have an 03 2500 4x4 running 20's. The reason I went to 20's is that I carry a heavy cab over camper much of the year, and even with load helper springs, I got too much sway with the load. This I went to a shorter sidewall tire and that made all the difference in the world.
Yet I have run two sets of tires in 35000 miles and it is killing me. The tires I have used are the Toyo's, good and grabby but good for only 20,000 miles max. I have not been able to find any options other than these that would garner me more mileage or less cost. Any suggestions would be greatly appreciated.
As a side note, when I put the tires on I had no reduction in mileage: 22 hwy, 17 city
itch, Do you have 20X 8,9 or 10s? Don't try nittos, there worse than the Toyos on mine. I've had two sets of 305/55/20s now, and I think I'll try 325/60/20s if they will fit, does anyone know for sure??? Those 275/65/20s are almost 35" and pretty skinny.
I have the Nitto Terra Grapplers, 275/65R20 on 20X8.5's. They are a 10 ply tire with a load rating of 3750 @ 80 PSI. The specs are 34 inches tall, 11 inches wide. Fit fine without leveling. The key to making them last is rotate religiously(so I hear) Mine have been on for about 1500 miles. So far , so good.
Sasqoutch
Nov 10, 2008 10:51 AM
lwcmattlifter
Jan 4, 2007 05:23 PM
97on22s
Feb 13, 2006 09:33 PM
