2004.5 3500 leveling
Old 06-03-2009, 09:39 PM
brianblack138's Avatar
I recently put a massive ranch hand replacement bumper on the front of my 3500 and noticed that the added weight has definitely lowered the front of the truck. The shop I bought the bumper from suggested a leveling kit. I've seen a lot of people recommend the Hell Bent Steel leveling kits available on ebay. Are there any downsides to installing a 2" leveling kit? Does it alter the handling or risk damage to the truck in any way?
Old 06-04-2009, 02:27 PM
turbochabot1's Avatar
I just put the Hell Bent Steel 2" kit on my truck along with some Bilstein shocks. Install was relatively easy, alignment was good when I had it checked after the install. Some also put on a new traction bar as the axle does get shifted over slightly. I have not yet as it has not affected how the truck drives but may upgrade my traction bar in the future. I would however recommend some drop blocks or longer sway bar end links as mine ended up bent within the first week. I just put some Maxx end links on mine so hopefully no more problems.
Old 06-04-2009, 10:00 PM
5.9x2's Avatar
I have had a 2" level on my 94 for 2-3 hundred k miles, no problems. I just installed 2.5 in on the 04.5 it moved my wheels back a bit but I am sure the front end alignment will resolve that as There looks to be plenty of adjustment in the lower arms, I will probably install longer sway bar links although looks ok at the moment. I would think that if you have added weight in the front the sway bar links may be ok. Also my shocks were maxed out with the 2.5" kit so I lowered my shock towers 2".
Old 06-05-2009, 07:24 AM
Fisherguy's Avatar
An alignment will not correct the diff being pulled over, you need a new adjustable TRACK bar to fix that. The adjustment on the lower arms is for camber and will not help.
I have a 2" leveling kit in mine, it doesn't bother me enough to change the track bar, drives straight and I have no problems.
Old 06-05-2009, 02:16 PM
Steveareno's Avatar
leveling
Installed Lorenze 2" last week, also have bumper and winch.
https://www.dieseltruckresource.com/...y-t244398.html
Old 06-05-2009, 08:04 PM
Booboo's Avatar
I have a 2" Kore kit easy install great kit drives straight no problems
Old 06-07-2009, 08:31 AM
gsbrockman's Avatar
Do you really mean "caster" ?
Greg
Old 06-07-2009, 10:34 AM
Fisherguy's Avatar
Greg
Oops, you're right, I meant caster.
gsdog1
08-03-2004 10:01 PM
drno
06-18-2004 06:57 PM
bmallen
02-29-2004 10:30 PM
shortround
02-28-2004 12:06 PM
Huntindad
02-09-2004 06:45 AM
Quick Reply: 2004.5 3500 leveling
