$2000 to spend on upgrades, which ones would be the best??
Old Oct 26, 2007 | 08:35 AM
BigDodgeBigHart's Avatar
I have the 300hp(60 HP) injectors, a 8" cold air intake, and 4" exhaust. What would be the best add ons for my money? I was thinking of a boost fooler with the J hook for about $120 and maybe an Edge, Banks or XZT controller??
Thanks for any and all input!
Old Oct 26, 2007 | 08:37 AM
rustyshakelford's Avatar
tranny or clutch improvements, fuel system, turbo...
brett
Old Oct 26, 2007 | 09:17 AM
mx684's Avatar
guages, fuel system, tranny/clutch, all that stuff, in that order, would be the way to go in my opinion..
Old Oct 26, 2007 | 02:38 PM
seabee's Avatar
since you mentioned a j hook im going to take it that you have a auto . so first things first gauges , then i would do a valve body and converter if the the trans is fresh . you can take it to your local tranny shop and have the do a pressure check on it to see if theres any internal bleed by on aany of the seals. to make sure that your trans is healthy enough for the added stress the valve body will put on the seals
Old Oct 26, 2007 | 02:40 PM
Bjans's Avatar
Throw a fass fuel system on there, a j hook and a module. id either go with quadzilla or edge. Both are great but quads new stuff is updateable.
Old Oct 27, 2007 | 11:25 AM
qzilla's Avatar
If you get the XZT+ module then you do not need to purchase a boost fooler. The XZT+ does boost fooling even in the "off" position.
Old Nov 2, 2007 | 10:46 PM
Thanks guys, will do that then, I was leaning towards the XZT too!!
Old Nov 3, 2007 | 08:15 AM
Ph4tty's Avatar
Guages, fuel system, box, and a j-hook (if you have an auto). If you're not broke at that point look for clutch/ tranny mods.
Old Nov 3, 2007 | 08:44 AM
97' CTD's Avatar
I would put Tranny First hands down without it you aint movin!!!!!!!
Brandon
Mexstan
Dec 2, 2012 06:28 PM
oleblue
20
Mar 23, 2011 07:16 AM
1993CTD
Feb 21, 2008 07:41 PM
Tim9712v
Jan 24, 2005 05:22 PM
rmb93243
Jul 9, 2004 12:51 AM
