2000 front axel under my 1998 12v
Old 01-11-2008, 07:50 PM
heykw's Avatar
I found a deal on a front axel out of a wrecked 2000 diesel I believe that it should all bolt up and it also has the correct gear ration I need to match my rear end which is now 4.10 (the front axel is 3.55). The reason I am doing this is to be able to do the big brake upgrade. Any input guys?
Old 01-11-2008, 08:57 PM
heykw's Avatar
Help it is out of a 2000 dodge
Old 01-12-2008, 01:07 AM
Dr. Evil's Avatar
There is no difference between a 98 and 2000 Dana 60 front differential (other than maybe the gear ration - which you already know about). Should bolt right in for you.
Old 01-12-2008, 06:12 AM
JD730's Avatar
I can't think of any issues with installing it, should bolt right in. Just remember when ordering parts or when someone is working on the front end.
Old 01-12-2008, 06:35 AM
heykw's Avatar
The brakes are different on a 2000 you can just slip the rotors off of the 2000 wear on the 98 you must remove the hub assembly to but a new rotor on from the back side.
Old 01-12-2008, 08:00 AM
b4wheeler's Avatar
Physically, any coil sprung dodge front end will fit under any truck that has a coil sprung front end. I was going to put a D60 form a 3/4 1 ton nder my 1/2 ton. Everything bolts up perfectly. You may have to get different brake lines, but that should be it....
Old 01-12-2008, 02:40 PM
heykw's Avatar
How about the abs stuff will they just plug in my 98 has abs?
Old 01-12-2008, 04:02 PM
b4wheeler's Avatar
Do you have both rears now?????
Just do a little parts swapping and get it working. You may have to swap sensors,or tone rings, or axle shafts, but the general housing and suspension is all the same.
Old 01-12-2008, 09:20 PM
heykw's Avatar
Yes I have the old rear I am talking about installing 2000 4.10 front to match my 4.10 rear the front currently is a 98 w/3.55 gears
Old 01-12-2008, 10:44 PM
b4wheeler's Avatar
I'm sorry.....
Even I am confused after reading my post....
What I meant to say was, do you have the diff that you are going to put under your truck already???
If so, put them next to each other and compare them. You should see what will swap and what won't.
But the real answer to your original question is..... Yes the newer differential will bolt right into your truck. all suspension and steering will bolt right up.
You may need to swap abs or brake parts.
Old 01-13-2008, 07:10 AM
heykw's Avatar
No I don't have the new front yet. I am trading a ford engine for it. Thanks for the input.
dieselnewb
09-06-2014 09:53 PM
JD730
0
07-02-2010 10:29 PM
smokinram99
23
03-24-2008 07:39 PM
JImbo1
04-09-2003 07:46 AM
Quick Reply: 2000 front axel under my 1998 12v
