2-1/2" or 3" crossover?
Title pretty much sums it up. I am going to upgrade the '89 with a 60mm compressor with a 2-1/2" outlet. Will build a new crossover to fit. Should I just make it the same size as the outlet or will 3" be better?
For you guys that have done it, you swap the plenum cover end for end? Is this necessary or just makes it a straighter shot?
The air is cooling down as it crosses over the motor, so going larger then the turbo outlet isent a problem I went with 3" when I upgraded my turbo, I do still have one extra mounting flange I had made that is out of 1/2 steel.
PS I am using a air to water intercooler that is 3"aswell.
I forgot to mention, but yeah the grids are going too. Will probably retro-fit them onto the grader.
Already have the gasket for the plate. Have contemplated building a new top altogether. We will see.
3" it is.
Thanks Guys.
3" it is.
Thanks Guys.
I can take pictures tommorow its not complete yet ordered my silicone couplers a few days ago. I am using a geo metro radiator with a flexalite fan using a ford intercooler pump for its own closed loop air cooling system.
Mike
Mike
make an account at a place like photobucket.com and upload them there and then it will give you a direct link to the pictures. you want the one with the [img] picturelink [/img]. post the code in the reply box here and it will show up when you post.
post here goes... be nice to me guys this is my first time I have ever tried to build anything like this
http://i394.photobucket.com/albums/p...n/IMG_0538.jpg
http://i394.photobucket.com/albums/p...n/IMG_0537.jpg
http://i394.photobucket.com/albums/p...n/IMG_0536.jpg
PEAKSTRYDE
Oct 11, 2007 04:20 PM
PapeCAT
Jul 17, 2007 06:59 PM
shortround
Oct 29, 2004 09:09 PM
