1998/2001 rear end gears
Old 08-23-2008, 05:26 PM
5Oclock's Avatar
Are the 1998 and 2001 2500 rear ends the same in that the gears are interchangeable?
Old 08-23-2008, 07:45 PM
JAX
JAX's Avatar
It depends on the transmission that is in the truck. If the truck has a manual transmission then the rear end will be the Dana 80. If the tranny is an auto, then the rear end is a Dana 70. You can interchange the 80s with each other, and the 70s with each other, but you can not change use a Dana 80 carrier and gearset in a Dana 70 housing or vice versa.
Old 08-23-2008, 11:04 PM
5Oclock's Avatar
Thanks. Both are/were auto tranny's. He swapped out 3:77's for 4:11's after about 40K miles. He has since sold the truck but has the gears and will give them to me for a case of beer. Then all I have is the labor to swap my 3:54's for the 3:77's.
Old 08-24-2008, 07:56 AM
Registered
blackdiesel's Avatar
Do the math, his are probley 3.54 also. Don't think there were 3.77's in 98. Save your beer.
Old 08-24-2008, 09:21 AM
dozer12216's Avatar
Me neither. Not sure aftermarket even has for DANA 80. Were not all Diesels 80's during that time frame?
Old 08-24-2008, 12:35 PM
5Oclock's Avatar
3:73 maybe?
Old 08-24-2008, 01:27 PM
Tate's Avatar
You can get Dana 3.73 gears, but just not in our application from OEM. Not sure switcing from a 3.73 to a 4.10 set would be worth it, or a 3.54 for a 3.73. Thats a 5% change in final drive ratio.
Old 08-24-2008, 06:25 PM
haloman's Avatar
Manual trans got the 80, auto got dana 70
1998 12vavle
06-01-2014 08:36 PM
doorguy
06-08-2007 06:19 AM
93beater
02-28-2007 09:28 AM
badmrb
05-27-2005 05:48 PM
13
03-29-2003 11:46 AM
Quick Reply: 1998/2001 rear end gears
