1996 Ram cruise control
Old 07-07-2005, 09:06 PM
TxDiesel007's Avatar
Guys
Cruise control worked fine when i put in the new pcm, but on a trip to falls city i lost the cruise first shot off in the morning, the little light comes on, but when i hit the set acceleration, it does not stay put, Loose wire somewhere? I have looked thru the search on the forums but found nothing havin to do with the set acceleration not working..
Tx
Old 07-08-2005, 04:56 PM
dalton4's Avatar
Check your vac. line under the driver's side battery. The line, 1/8 " I believe, have failed due to battery acid or other causes. This happened to me and gave the same results as you posted.
Old 07-08-2005, 08:32 PM
12vordie's Avatar
Same thing happened to me and it was the hard plastic line under the left battery where it hooks to the cruise servo, it had broke, I spliced it with some rubber vaccum hose.
Old 07-08-2005, 10:07 PM
Mopar1973man's Avatar
Vacuum hose...
This is a very common fault with the cruise on this model. Check the plastic tubing and the rubber fitting too! I've had both fail now!
Old 07-10-2005, 12:34 PM
Thank you fellas!
PROBLEM SOLVED!!
Tx
Firstgenfanatic
11-08-2009 04:05 PM
Landini1
03-06-2009 07:01 PM
orlandfrey
11-03-2004 08:26 PM
sam
03-31-2003 09:04 PM
TexasDiesel
12-27-2002 10:47 AM
Quick Reply: 1996 Ram cruise control
