1994 dodge 3500 -no power
Old 12-09-2003, 01:34 PM
BILL32570's Avatar
I have a 94 dodge diesel 3500, all the way up till this morning I have had no problem,Woke up this morning to go to work and got in my truck and left- very slowly! I do not know what could be the problem since It was fine before.Now a big loss of power. any help, Thanks
Old 12-09-2003, 01:39 PM
Smokee's Avatar
Re:1994 dodge 3500 -no power
The first thing to check is, of course, the filters. Next, check for a leaking intercooler boot. After that, I do not know, unless you got some bad fuel or the timing slipped.
Good luck.
george
Old 12-09-2003, 08:47 PM
bulthisl's Avatar
Make sure the shutoff solenoid is pulling lever all the way up.
If not you won't get full fuel and will have less power.
If it's not retracting all the way clean rod and that may fix.
If not could be bad relay or weak solenoid
: Eddie : 8)
Old 12-09-2003, 10:06 PM
yomitch's Avatar
make sure you have cleaned the screen in the fuel heater as well as it's the first thing to see bad fuel
Old 12-10-2003, 12:04 PM
RCW
RCW's Avatar
Definitely check your filters, the screen in the fuel heater, and fuel hoses, but the 94 came from the factory with a short-lived one-piece overflow valve in the injection pump. Check to be sure you have the two-piece valve, and if not, I would suspect your problem is right there.
Do not waste your time getting way overpriced replacements from Dodge, either go to Cummins or one of the advertisers for this site.
Old 12-10-2003, 02:04 PM
MnTom's Avatar
If you need to get an overflow valve, BE CAREFULL at Cummins. They charged me $84 for one!!!!!
Tom
gn4life
2nd Gen All Products
09-17-2015 09:13 PM
nbaggett89
11-05-2008 06:43 PM
travandmary
06-26-2003 10:43 PM
Quick Reply: 1994 dodge 3500 -no power
