14 bolt questions
Old Dec 11, 2009 | 09:36 PM
dig'umz's Avatar
14 bolt questions
I finally broke the 70 and I think I'll go 14 bolt this time. Any of you guys that have done this care to share some secrets?
Will the brake line thread together or will I need new ones?
I can build perches and shock mounts, but will the drive line need to be modified?
Thanks for any help.
Jeremy
Old Dec 11, 2009 | 11:49 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
Not sure on the brake lines but you will need to source a 1410 yoke for the 14bolt as most 14b's had a 1350
Old Dec 11, 2009 | 11:53 PM
simplysmn's Avatar
iF i REMEMBER RIGHT YOU CAN USE THE STOCK DODGE SHOCK MOUNT'S the brake line should bolt right back up no problem as for drive line you should be ok or darn close to ok
Old Dec 12, 2009 | 02:56 AM
big stinky's Avatar
and 3.54 isnt a gear option in the 14bolt.
Old Dec 12, 2009 | 06:18 AM
dig'umz's Avatar
I think I know were some 3.73's are. The rear end I've found is 4.10's should be able to swap gears. What would a yoke that big come on?
Old Dec 12, 2009 | 08:19 AM
CE_TX's Avatar
Brake Line.
You will need to get a new brake like made from the frame to the axle. The end off your stock dodge one will not fit the splitter (Y) on the 14FF.
Old Dec 12, 2009 | 11:07 AM
big stinky's Avatar
Sorry, didnt notice you were 2wd. They make a 3.42 for it if that helps... You can buy yokes new from a driveline store.
Old Dec 12, 2009 | 08:16 PM
NO_SPRK's Avatar
I think you can have up to a 10% difference in gears without blowing your t-case
Old Dec 12, 2009 | 10:49 PM
440trk's Avatar
I think you mean 1%.....
Old Dec 13, 2009 | 09:51 AM
dig'umz's Avatar
Thanks for the info
FordTrax
Apr 18, 2014 08:47 PM
Rpainter
Jan 28, 2007 09:10 PM
latitud_rt
Oct 23, 2002 08:19 AM
