12v wont start
Old May 11, 2009 | 09:32 PM
D32C's Avatar
12v wont start
I just finished doing the KDP and resealing the front gear case. All went well, started her up, ran great. Ran for at least 1/2 hour, checked for leaks, all good. Drove onto the road, began to accelerate, HUGE backfire, then several smaller ones, no power no go!!!!! Shut it off and at first it would crank over and attempt to start, but now it just keeps on cranking over with not even a hint of a sputter.
I had to remove the overflow valve on the injection pump to reseal the gear case, I plugged the opening being ever so careful not to get any dirt in there, then when all was said and done, I changed the washers for the overflow valve and replaced the fuel filter. I bled the fuel system. Now all I get is white smoke!!
HELLLLLLLLLPPPPPPPPPPPP!!!!!!!!
Old May 11, 2009 | 09:43 PM
BigIron70's Avatar
Cummins Guru
Did you pull the gear on the injection pump?
Old May 11, 2009 | 09:52 PM
D32C's Avatar
marked it, pulled it
Old May 12, 2009 | 07:14 AM
patdaly's Avatar
Bet it slipped on you.
Pop the cover and check out the Inj pump gear.......
Old May 12, 2009 | 10:50 AM
infidel's Avatar
Definitely sounds like your timing slipped... big time.
See if this can help you, no need for a dial indicator or DV socket.
http://www.cumminsforum.com/forum/94...ack-stock.html
Old May 14, 2009 | 08:56 PM
patpat paul's Avatar
145 lbs on nut wont do tightn to 165lbs this just happend to me exacly the same as you retime pump and motor and tourqe to 165 will run fine.
Old May 17, 2009 | 08:57 PM
BigIron70's Avatar
Cummins Guru
There must be absolutely NO OIL on shaft or gear. If there is they will slip. Clean off really good with brake clean and clean rag.
400Magnum
Dec 21, 2009 06:32 PM
rynojr4644
May 18, 2009 07:23 AM
judgester
Nov 25, 2008 09:57 PM
qcstunter
Jan 9, 2007 04:10 PM
troutbum
Mar 6, 2006 03:40 PM
