11/32 drill bit for 1/8" tap?
Old Aug 22, 2005 | 06:47 PM
Graphite600's Avatar
Can I use an 11/32 bit to drill for an 1/8" npt tap? Says on the tap use q drill bit, but will an 11/32 size bit work?
Old Aug 22, 2005 | 07:14 PM
GreyTD's Avatar
11/32" is 0.012"larger -- can see it being a problem. Someone will correct me if I'm wrong
Old Aug 22, 2005 | 08:02 PM
ds1rider's Avatar
Whats this for? Pyro?
Old Aug 22, 2005 | 08:42 PM
bmoeller's Avatar
Drill chart
IIRC, I used a 5/16" bit for my 1/8 NPT tap. If were to use a 1/4" NPT tap, it would a 7/16" drill bit.
Old Aug 22, 2005 | 11:34 PM
Aloha's Avatar
I used a 21/64" bit. Worked fine and was available everywhere I looked. Luckily I had one and after sharpening it had no problems. I think it's more important to drill a very straight hole. A bit that's 1/64" + or - probably has less effect on the tapping process than a hogged out hole or one that's improperly cut.
Aloha
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
finndogg54
Sep 17, 2007 11:12 AM
Hoss
Apr 11, 2006 11:37 PM
Dodgezilla
Aug 22, 2004 06:12 AM
