03 cuts out when driving
Old 05-10-2011, 07:17 PM
ataboy9026's Avatar
My truck has done this 2 times now... all gauges and engine blink off for a second when driving . Then as soon as I see all my gauges swing to zero and feel a hesitate in throttle it comes back to normal. This only lasts for one second. Any ideas?? While driving I turned off key and then back on and it acts the same as when it blinked out.
Old 05-10-2011, 08:09 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Check the ground connection on the drivers side battery. The ECM or (Engine Control Module) grounds here and the connection could be loose or corroded.
Old 05-15-2011, 11:42 AM
ataboy9026's Avatar
Well I took off every connection and cleaned them up with wire wheel on my cordless drill... everything is allright now.
Old 05-15-2011, 11:59 AM
Administrator/Jarhead
madhat's Avatar
Also, how old are your batteries? When they start to go, they cause a lot of problems.
Cummins Guru
BigIron70's Avatar
That's great, stop further corrosion with battery terminal sealer. Comes in spray will prevent corrosion from forming on terminals.
Ram of Steel
04-10-2008 11:49 PM
janb
01-10-2005 02:05 AM
janb
01-02-2005 08:19 AM
BigBlue
10-16-2003 03:57 PM
fishermansteve
04-13-2003 09:22 PM
Quick Reply: 03 cuts out when driving
