03 6 Speed High RPM's Between Gears?
Old 06-01-2010, 09:08 PM
notw's Avatar
I am about to make the move from my 95 to an 03. Found a great one with the 6 speed. The only problem with the truck according to the owner is that it doesn't idle down between shifts. Beyond that it behaves normal. I have searched and found many threads about this but never a solution. Some suggest a lift pump, others injectors, and some a bad ground or computer problem. Has anyone ever found a solution to this problem? I can't afford a new truck and injectors at the same time. Any advice would be greatly appreciated.
Old 06-02-2010, 08:09 PM
mitternocht's Avatar
I wouldn't say my truck revs between shifts, but it doesn't go to idle either. The typically G56 shifts fast so the RPMs are generally about right for the next gear. Not sure if this helps. The CR's need a bit of time to bleed off rail pressure between shifts when you are into it too. I never drove a 2nd gen stick, so we'll see what other have to say about the 3rd gen sticks.
Old 06-02-2010, 09:38 PM
Jim O's Avatar
I agree I have the NV5600 and it is the same the rpm drop is just about right for the next gear. The only second gen stick I ever drove was equipped with a NV5600 and although it was several years ago I believe it acted like mine.
Jim O
Old 06-02-2010, 10:46 PM
notw's Avatar
Thanks for the replies, that makes me feel better. I believe the current owner is describing the same scenario as you both are. The engine takes awhile to decrease RPM's between shifts. He said it has done it since he bought the pickup. Guess I will be in a 3rd soon. Thanks again.
Old 06-03-2010, 06:21 AM
MikeyB's Avatar
It's somewhat normal for the rpm hang on the manual shift CR engines. The rpms hangs (especially at high rpms) due to the fact it's takes time to bleed down the rail pressure after dropping the throttle. The sweet spot is to shift around 2,000-2,200 rpms.
If the rpm hang for extremely long time (more than a few seconds) it's usually a indication of a sticking FCA or sticking injectors.
MikeyB
Old 06-03-2010, 10:12 PM
Rod_Montana's Avatar
You're climbing a hill in 4th or 5th gear, spinning up to 2000rpm with 30psi of boost and 26k psi of fuel pressure in the rail, making about 300hp. Let off the pedal and throw in the clutch to shift.
Are the rpm's going to drop right now? Not likely. But fuel and air pressure bleed off in the second it takes to get the next gear. Nature of the beast.
Old 06-04-2010, 12:52 PM
buckied's Avatar
I've noticed that after adding the edge mileage max that mine stays up longer between shifts, it's actually easier to drive now because of it
Old 06-04-2010, 01:06 PM
Jeff in TD's Avatar
Both 3rd gens I've had would accelerate briefly when you pulled your foot out of it, if you were at full power in higher RPM's.
From talking to other folks, that seems pretty normal. I'd guess it is just the boost pressure and rail pressure are still high.
99.5% of the time I'm taking my foot off the pedal less abruptly, and it behaves.
Old 06-04-2010, 01:19 PM
AH64ID's Avatar
Probably due to the increased rail pressure of the ez... hope you upped your filtration too.
Old 06-04-2010, 06:14 PM
buckied's Avatar
Such as??
Old 06-04-2010, 06:51 PM
AH64ID's Avatar
Such as??
Easiest would be a Baldwin PF7977 in the OE canister.. But at the least run only the Baldwin, OEM, or Donaldson filter.. none of the others meet OE spec..
If you want more the MK2+ kit from GDP with a Donaldson P551313 or Cat 1R-0750 is a good option.
Old 06-04-2010, 07:33 PM
buckied's Avatar
I normally just use a napa gold fuel filter, and I change it every time I change my oil... you're tellin me that's not good enough?
Old 06-04-2010, 09:19 PM
C Schomer's Avatar
The rpms hang between shift with my 03, too. Low rpm is not bad but pushing it hard at higher rpm is worse and a hot download/running hard makes it stay up there til I let the clutch back out and pull it down. I've talked to friends with 03s and you just have to get used to it. Craig
Old 06-04-2010, 09:46 PM
etn550's Avatar
Sorry to disagree....
And no flame intended, but the hang is all programming to ease the speed down to prevent hydrocarbons in the exhaust emissions.
Rail pressure does not go anywhere if the injectors are not fired. Same lack of response if you blip the throttle. The p-pump engine will really bark when the pedal is stabbed. These CR engines just sort of roll in and out of it. If you want to see haw fast it will roll down turn the key off when you shift it!
I miss the bark! I used to make the '96 engine bark if someone in front of me at a traffic light did not move when the light changed. Worked every time.
Old 06-04-2010, 11:57 PM
Rednax's Avatar
Just be glad it ain't a Caterpillar . . you could dial a phone call and get the first sentence in before those things drop.
Yeah, they're slow. They're real motors.
Quick Reply: 03 6 Speed High RPM's Between Gears?
