Any ideas to increase initial horsepower in reverse
Old Mar 27, 2007 | 06:08 PM
coloradotruck's Avatar
I have a 2001 auto trans. with 156,000 which I use to haul Hallmark slide in camper for recreation.
I find it very hard to back the truck up in reverse up hill from a stand still.
When I give it more gas it just puffs black smoke and doesn't want to move.
Any ideas how to increase RPM's on an automatic trans to get it over the hump.
Once the truck is rolling and the RPM's increase it does fine.
Just replaced Air filter with K&N and did not help.
thanks
Old Mar 27, 2007 | 06:09 PM
rustyshakelford's Avatar
thats the T/C. if your 4x4, put it in low range
brett
Old Mar 27, 2007 | 09:23 PM
Teddy Bear's Avatar
You might want to look into a 2wd Lo kit. They are ideal for pulling/backing trailers around
Old Mar 27, 2007 | 09:49 PM
It is 4x4 and I will try the low gear next time.
One more reason to go with the standard transmission next time.
Old Mar 27, 2007 | 10:24 PM
Box5's Avatar
swap one in, lol
Old Mar 27, 2007 | 10:44 PM
ratsun's Avatar
4 low will make a huge difference.
There was a write up on how to wire up a toggle switch so you cut out the vacuum to the front dif when you put it in 4low so you dont engage the front dif and dont get the crab walking. I cant find it but maybe someone will put up the link.
Old Mar 28, 2007 | 02:12 PM
sleepr tsi's Avatar
http://www.cumminsdatabase.com/read.php?id=10
Old Mar 28, 2007 | 03:10 PM
ratsun's Avatar
Originally Posted by sleepr tsi
Good gob
That what I was talking about.
TexasJH
Oct 16, 2009 08:36 PM
gus's 03
Oct 8, 2005 08:30 PM
imelmo
Mar 3, 2005 08:59 AM
