1969 Ford Crew Cab Cummins Project...
Old Feb 25, 2010 | 10:57 AM
HRDROKN's Avatar
I have not been to this forum in a while as there wasn't a conversion section, but I guess this sub-forum has probably been active for a while now....
Being that this conversion is almost 3 years strong and not complete, I have tons of pics to share! Although most of you have probably seen them elsewhere.
Old Feb 25, 2010 | 11:11 AM
HRDROKN's Avatar
I was looking for something even more unique after my 85 Dodge Crew Cab Project so....
My wife and I took a trip to Arizona back in July '07 to pick up a 1969 Ford Crew Cab 4x4 that was rust free! Made a deal for the truck without motor and transmission... perfect canidate for a Cummins swap!
And it all begins....
Old Feb 25, 2010 | 11:12 AM
HRDROKN's Avatar
As it turns out the "rust free" truck wasn't so rust free! Typical buyer beware... Well, I should have looked at the truck closer while in AZ, but part of me just didn't want to find reasons to come home empty handed!
Old Feb 25, 2010 | 11:13 AM
HRDROKN's Avatar
More of the same....
Old Feb 25, 2010 | 11:14 AM
HRDROKN's Avatar
Getting busy with some floor pan repairs while planning out the particulars of the motor swap....
Old Feb 25, 2010 | 11:15 AM
HRDROKN's Avatar
Fitting new replacement panels.... this is my first go around with any kind of body work, so it has been somewhat of a learning experience!
File Type: jpg
Old Feb 25, 2010 | 11:16 AM
HRDROKN's Avatar
Finishing up with the passenger side.....
Old Feb 25, 2010 | 11:18 AM
HRDROKN's Avatar
Same business for the drivers side floor and front cab mount...
Old Feb 25, 2010 | 11:20 AM
HRDROKN's Avatar
Next big problem to solve..... Previous owner did a real hack job modifying the power steering mount to fit a 78-79 4x4 steering box. I thought about several options and decided complete front replacement...
Old Feb 25, 2010 | 11:21 AM
HRDROKN's Avatar
So I will be fabricating new frame rails and a new x-member. What I want to do is fit a new x-member further toward the rear to make room for the A/C pump in it's stock location. Otherwise my options are a top mount unit (might interfere with compound turbos or injection pump) or no A/C :haha
Think I will cut on the white line.....
Old Feb 25, 2010 | 11:23 AM
HRDROKN's Avatar
Found a 1993 Cummins 12 valver for the swap... I will be doing a P-pump conversion to this motor down the road!
Old Feb 25, 2010 | 11:25 AM
HRDROKN's Avatar
Taking a look at the motor mounts and such...... removed the stock x-member and added this plate to tie in mounts and x-member into.
Old Feb 25, 2010 | 11:26 AM
HRDROKN's Avatar
Working on motor mounts...... I just trimed the stock brackets that bolt to the block to fit the bushing.
Old Feb 25, 2010 | 11:27 AM
HRDROKN's Avatar
Drivers side motor mount...
Old Feb 25, 2010 | 11:29 AM
HRDROKN's Avatar
Motor mounts completed, x-member fabricated and frame rails removed....
