TXDTR #8 Forum for the Texas chapter #8
TXDTR #8 Sept Meet
Old Aug 18, 2008 | 10:01 AM
  #31
AggieJustin's Avatar
BTW, I found a good, easy to implement anti-theft feature over the weekend.
If you move the white latch on the big harness at the top of the firewall to the open position, the truck won't start. You don't have to unplug it, just move it to open. It only caused a small amount of grief...
Old Aug 18, 2008 | 12:05 PM
  #32
crobtex's Avatar
Sounds like a hard lesson learned.
Old Aug 18, 2008 | 12:26 PM
  #33
Diesel-Dan's Avatar
AND then how many codes are we resetting after all this? Reason is some of us dont have a Smarty yet! haha.....
Old Aug 18, 2008 | 12:43 PM
  #34
Not too bad. A little worried after the first couple of tries at cranking. Then when I didn't hear the lift pump, I was thinking that the LP died. Then just before pulling the plug on the pump and checking for connectivity, I figured I'd check for codes. That's when I discovered that I had no connectivity to the ECM. So I rechecked everywhere I recently had my arms and hands since the last time it started.
Just two.. No bus communication from ECM and a companion code. But they'd only be set if you try to start it.
Old Aug 18, 2008 | 12:56 PM
  #35
Diesel-Dan's Avatar
Good point...key off...no codes.....good tattle tale as well......
Old Aug 21, 2008 | 09:47 AM
  #36
Duallydog's Avatar
It's looking like the official meet for my crew will be at the pulls too. So there should be plenty of us...not pulling.
Old Aug 22, 2008 | 10:27 PM
  #37
camododge's Avatar
:chirp: :chirp: What happened to everyone?
Old Aug 22, 2008 | 10:40 PM
  #38
Just got off work about an hour ago, now packing to head to Giddings for a wedding this weekend.
Taking the car instead of the truck...that should be a new one. I always make that trip with the truck. So no highway testing this weekend...
Old Aug 23, 2008 | 09:53 AM
  #39
camododge's Avatar
Which injectors did you end up going with?
Old Aug 23, 2008 | 08:04 PM
  #40
crobtex's Avatar
How about a little head count for Alvarado.....
1) Me
Old Aug 24, 2008 | 08:21 AM
  #41
RowJ's Avatar
2) Me
Diesel this AM - $2.839 a Gallon!!!
Old Aug 24, 2008 | 08:51 AM
  #42
crobtex's Avatar
Originally Posted by RowJ
2) Me
Diesel this AM - $2.83 a Gallon!!!
$2.83 is pretty cheap............
Old Aug 24, 2008 | 11:10 AM
  #43
RowJ's Avatar
Got a little carried away. Would you believe $3.839?
RJ
Old Aug 24, 2008 | 11:31 AM
  #44
crobtex's Avatar
RJ
I almost headed that way to fill up. Still a lot better than down here.
Old Aug 24, 2008 | 12:26 PM
  #45
Duallydog's Avatar
Wow, I was about to head to Oklahoma myself.
Unless something comes up I'll be there, don't know how many of mine will come yet.
