when to shift with 15to 20k a g56
been pulling alot with truck and shifting about 2500rpm was wondering should a guy wait till 2800 rpm or what is the best in all gears also we have half mile hills at some unreal grade in these hollers dont know if people down here spell it like that or not
but this is my first hand shaker and was wondering
thanks
thanks
2600 rpm should be a good upshift point; seems just right on mine with the 3.73 diff ratio and stock tires. If running empty, about 200 rpm less seems just about right. The ECM begins defueling at about 2700 or so rpm, and the torque and HP curve starts falling off at about 2700, so anything past that isn't going to buy you a lot.
You can shift wherever you want, the important thing is that when you let the clutch out in the next higher gear, make sure you are at or above the torque peak.
Originally Posted by bigblock2stroke
Peak power is at 2900rpm so hopefully you aren't defueling at 2700rpm.
The engine will usually let you know when it wants to be shifted; when new and breaking in it seems like around 2500 it just doesn't want much more, after some break-in miles towing, it seems to take a bit more before letting you know it wants to be shifted.
I saw somewhere on the net where one of the new 600's were dyno'ed at the rear wheel don't remember tranny or ratio but peak torque was 2200 rpm and hp was 2800 rpm. if memory serves me correctly?
Little-bit
15
Dec 22, 2006 12:03 PM
MX429
18
Sep 3, 2006 05:52 PM
jaconst
Mar 30, 2004 01:05 PM
