Trailer lights
Old Sep 26, 2004 | 05:59 PM
azjeff's Avatar
Trailer lights
My truck has the tow package making the hookup as simple as plugging in the trailer connector. While using the trailer a few days ago, I have a removeable marker light on the extreme rear of the trailer where there is a lift gate attached, the light cord got stretched and broke. After repairing the broken cord the lights were checked & the running lights didn't work. There is a continuous hot battery lead at the plug and it was throwing me, because I couldn't figure why the lights wouldn't light. After 30 minutes of scratching my head I thought to check the fuse block and sure enough there is a 15amp trailer light fuse along with turns.
If you are having trailer light probs, it may save some time to check the fuses. Jeff
Old Sep 26, 2004 | 09:25 PM
clifford's Avatar
If it is like the older Dodges that fuse feeds a relay back in the wiring harnes by the rear bumper I found that the hard way.
Old Sep 28, 2004 | 04:43 AM
Dodgezilla's Avatar
My 03 has 3 seperate fuses for the trailer lighting. Running lamps, right turn, and left turn. I spent about an hour looking for a bad wire on a trailer before I finally checked the fuse box and found the bad fuse.....
gnarlykaw
Aug 22, 2004 07:52 PM
Amish hauler
Apr 8, 2004 07:07 PM
CHarlan
Aug 6, 2003 08:40 PM
