Trailer Light Wiring - Lights not working.
The wire was definitely hot. Gave a nice bright spark when i touched it to the trailer frame.... Truck wiring is how it came from the factory / dealership, 4 pin connector. i have not messed with or spliced anything into the trucks trailer wiring.
I did have a trailer brake controller installed.... is it possible that was wired wrong, or maybe now the white it supposed to be hot for trailers with brakes??...
Guess i need to get under the truck this weekend and take a look....
get a test light,white is ground and must be grounded to trailer frame,brown is running lights,green is p/s turn-brake,yellow is d/s turn-brake,hitch is not a ground and if you use it for a ground in some cases it will effect the trucks comp.
If your truck has a 4-flat from new, it may be installed wrong. If you are using a 7RV to 4-flat adapter, it may be wired wrong inside. I bought a Hoppy 7 to 4 adapter for my last truck that was wired wrong on the inside -- everthing was one pin off counter-clockwise! My current ride has a nice tow package, but looks like a crummy 4-flat install spliced into the back of the 7RV socket. Grrr. Will definitely need work before I hookup to any trailers!
here, this should help... note that the white is the ground on BOTH sides of the plug!
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
If you have trailer brakes, then you need to swap that flat 4 for a 5 or 7 pole connector that allows for the brake wiring in addition to what is listed above.
Does the white on the truck end ground to the frame somewhere in the rear?
I have the 4 to 7 pin adaptor for when i pull with brakes but have not permanently attached it cause i dont pull with brakes that often.
Thanks! Will post my findings... If i'm not back by sundown send in another 12er!!
Well it looks like i have a little project in the morning. I'm definitely going to ground the white on the trailer end. Gonna have to splice into the wire cause it's only about 2' long. not even long enough to reach the hitch
Sure, 2 feet is plenty.... If i just wanna do nascar laps in the driveway...
I spliced into it to added a little length and grounded it to the frame. Everything works (even with the trailer not attached..haha)
Still dont know why the white was hot, but it doesnt seem to have any power to it now... ??...
Thanks for everyones help!
if it was just a spark that made you think it was hot, then it was because it was grounding. jumper cables will do the same thing if you hook the hot up first.
Sleigher
May 4, 2017 02:12 PM
Marcus
Sep 1, 2008 03:54 PM
Bobs dodge
17
May 19, 2008 10:50 PM
pullin hard
Mar 18, 2007 06:46 PM
