Trailer battery not charging
Old Aug 25, 2008 | 11:19 AM
rogers259's Avatar
Ok I know its not the trailer because I've had several different trailers on the truck and when plugged into the 7 pin the battery won't charge or the lights in the trailer won't power up.
Is there a 12 volt wire I need to tap into or something to get the truck to provide power for charging the trailer battery?
Thanks
Old Aug 25, 2008 | 01:55 PM
hubmonkey's Avatar
I may be mistaken but without the truck running it will not utalize the batteries in your truck, this is to protect them from draining. When you run down the raod it should charge your house battery on your trailer.
Have you made sure all your connections are tight? Does you converter chanrge your battery when plugged into shore power?
Hub
Old Aug 25, 2008 | 04:13 PM
FiverBob's Avatar
The 12v line to the trailer is hot whether the ignition is on or not. Have you checked it with a meter? Real easy to do right at the bumper plug. You may only have a blown fuse under the hood or possibly no fuse in there at all. Usually a 40a.
Bob
Old Aug 25, 2008 | 08:31 PM
hubmonkey's Avatar
The fuse on mine is a 20a and it is located under the hood. I popped mine by accident with a short circuit.
Old Aug 25, 2008 | 10:19 PM
TonyB's Avatar
Some trailers (my camper did) have a battery isolator on the incoming + side from the truck. These don't work so well. Mine died; I just wired it direct, with a 40A fuse on 8AWG wire.
HTH
Tony
Diesel-Dan
20
Sep 22, 2019 09:34 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
Mechanos
Dec 21, 2004 08:56 AM
robo
May 6, 2004 02:15 PM
Amish hauler
Apr 8, 2004 07:07 PM
