"Tired" of getting stuck off-road
Hey guys, I need some advise and opinions. I use my truck 80% of the time/miles for towing my 11K, 25', TT toyhauler. Yes, it is a 2007 with just over 13K miles. I have stock michelin tires and suspension. I'm sick of getting stuck in soft dirt or just a bit of sand while in 4x4 when I go camping and have to go off road.
I picked up a set of some used forged Powerwagon rims that I was thinking of powder coating a dark color grey, teflon, black, etc. What do you guys think? Anyone done this? What about the caps? Pictures? Now for the tires? What is suggested to keep me going in the dirt and yet behave as needed when towing? What sizes would be best? I'd like to go bigger and would do a leveling kit up front if needed. Best brands for the tires? Sorry for all the questions. I value the great knowledge and tastes of the guys on the DTR forums :cool: |
As you mostly drive on road use a good road tire but carry a set of chains for going off road, chains are not only for snow..[laugh]
Off-road just about anything will be an improvement over the stock Michelins. You need an All Terrain tire (as opposed to All Season like the Michelins). I tried BFG ATs, a buddy of mine tried the Toyos on his CTD. We both are now running the Hankook AT-Ms and are very impressed with the great traction and wear (or lack thereof). Have not ever been stuck with the Hankooks and I drive in snow, mud, snowy mud, sand, etc. Be prepared for a 1-2mpg drop though, if you go bigger (285-70s).
285/75/17 Nitto Trail Grapplers.
With the miles you drive they will dry rot before you wear them out. Probably wouldn't need a leveling kit so you won't have to worry about screwing with towing and suspension geometry. They are a little squishy at first but ride and drive just great. More aggressive than A/T. |
Thanks guys for the good suggestions (not counting Busboy). Yes, even my Michelins are dry rotting and they look brand new! So, I'd like to get as aggressive of a tire as I reasonable can that I can still tow safely with. Also, it is probably best to stay away from tire sizes that I'd need a leveling kit for. So, the 285/75 is probably the way to go huh? Keep 'em coming guys...
I have never been stuck neither off road nor in the snow with my Michelins LT265/70R17/E tires. I am an old jeepster from the 70's and I learn a long time ago a very valuable lesson when running my jeeps off road on the sand and dirt. I would air down the tires to a lower air pressure setting. This provides a larger surface area for the tire to spread out and will keep the vehicle from getting stuck. You just have to go slow and easy no speed in this case or trailer towing.
I carry a portable air compressor with me to air the tires up when I reach payment or a hard pack dirt road. Jim W. |
1 Attachment(s)
These, 800 miles on these tires, see the wet grass? [laugh] Had to have an F150 pull me out.
Attachment 58880 Or these? http://www.offroaders.com/tech/AT-MT...appler-250.jpg I use the second tire now. |
Originally Posted by mega-engr
(Post 3081482)
I'd try this size first without a lift to keep it simple. good luck! |
when in sand, you need to let a lot of air out of your tires. To the best of my knowledge you can have the best tires money can buy and your still going to get stuck.
also some time unhooking and checking your path without trailer attached may help you avoid getting stuck. Driving in sand takes some practice. it is not something you can just creep through. speed and momentum are necessary to avoid getting the chains out |
Mega, I haven't tried the Hankooks but ran some Toyo 265/75 ATs on my '99 2nd gen 4x4. I lived in sandy country at the time. The toyos wore very well even with all the heat and heavy towing (mostly hay & equipment) and did much better on wet clay and dry sand than the BFG and Coopers I had tried. But yeah, you should be able to get by with a 285/75.
Originally Posted by Jim W
(Post 3081556)
I carry a portable air compressor with me to air the tires up when I reach payment or a hard pack dirt road. Jim W. So, I just think a better tire will get me through most of these situations and of course when the going gets tough, I need to do the right thing with any tire.
Originally Posted by Rednecktastic
(Post 3081567)
http://i133.photobucket.com/albums/q...Picture067.jpg Or these? http://www.offroaders.com/tech/AT-MT...appler-250.jpg I use the second tire now. |
(Post 3081570)
Toyo also makes a M/T in the 285/75 size.
I'd try this size first without a lift to keep it simple. good luck! Toyo Nitto Hancook In the 285/75 size. Then consider the AT or MT versions. |
(Post 3081482)
Have a look at these http://simpletire.com/multi-mile-lt2...17-xts91-tires I think they will be our next tire. I have compared them side by side with the Nitto Grapplers and the Nokian Rotiiva AT, these look better. They are a relatively new tire but the local phone company here is using them on ALL their trucks. They are supposed to be quiet on the hiway and give good mileage. If you do buy a more aggressive tire throw a pair of tire chains in your toolbox for when you do get stuck with that trailer.[laugh] |
Originally Posted by Busboy
(Post 3081641)
[laugh][laugh] While you may discount my suggestion right off the bat, the people suggesting tires are not pulling a trailer off road. The more aggressive the tread the poorer the fuel economy and noisier on the hiway.
Have a good look at the tire I suggested in real life, I think you will be impressed, like I said it will be our next tire, and the price is good. It has a 16mm tread depth, good siping and the grooves are full depth all the way to the side of the tire. Unlike some that reduce the depth at the sides so once its worn a little they could hydroplane easier because the water can't get out quickly.
The beauty of using chains is you don't have to adjust the tire pressures, my son takes a cargo trailer places you wouldn't think possible, he slips on the chains just on the rear and out performs trucks with no chains and no trailer. |
