stock tires
Old Jun 22, 2010 | 10:58 PM
jwatso8's Avatar
stock tires
I still have stock tires on my truck. My problem is speeding up or slowing down i get a real bad walking in the rear of the truck around 30-45MPH (side to side). Another thing is i dont know if the short wheel base or what but it real bad on bumps loaded or not. The truck is a 2007 5.9 6speed (G56), quad cab, short wheel base, 2x4, with air bags. The trailer is a 2010 20+5 ProTrak trailer 4,700lbs and 2005 Bobcat T190 7,600lbs. So total weight pulling is 12,300lbs and im pretty sure i got it load 60/40 like it sould be. The air bag pressure is set at 30psi and if i let it down it gets worse. Should i air them up more or is it the tires side walls rolling. Thanks guy's
Old Jun 23, 2010 | 06:26 AM
MikeyB's Avatar
Is the trailer a goose neck or tag?
Just a guess but it sounds like to me there's not enough tongue weight. Does both the truck and trailer sit level when loaded? Running max air pressure on the truck and trailer tires? If it's a tag do you have a anti sway bar attached?
MikeyB
Old Jun 23, 2010 | 12:23 PM
jwatso8's Avatar
im sorry, its a gooseneck 20' deck and 5' dove tail. with the air bags i can make the truck sit level. and the air pressure is at cold max on truck and trailer. ill try it with more tongue weight, and see if that helps.
Old Jun 24, 2010 | 08:12 PM
induchman's Avatar
When was the last time you rotated your tires or had them inspected?
chrisminx
14
Jul 7, 2010 06:48 PM
1320
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Captain
Sep 9, 2005 12:16 AM
