RV batteries
Old May 27, 2003 | 03:25 PM
RAFTEN's Avatar
Re:RV batteries
KTM, Gary, can I ask what the outputs of your solar panels are? At what point do you need to add a solar controler? I have been told if you have more than one battery and a lower output panel you don't need a controller.
Old May 27, 2003 | 04:39 PM
FiverBob's Avatar
Re:RV batteries
KTM,<br>You are right about nice fresh batteries. I am milking mine right now before replacing. The &quot;smart&quot; charger has helped, but I can drop them pretty quick with that inverter. Sure nice to be able to sit dry and not run anything. <br><br>Raften, I use a 15w solar charge unit to keep the batteries up when not using the coach. It has no controller. I am holding three batteries, so there is not a whole bunch left over. I turn the main disconnect off, then activate the solar switch. It will hold them very nicely, especially when they are fresh and I see no boiling off.
Old May 27, 2003 | 10:58 PM
misterKTM's Avatar
Re:RV batteries
Here is a link to what I have. I do have the controller as well. It cycles off @ 14.2 volts, then back on at 13.0 volts. With the new batteries I did see it turn off the solar panel in the late afternoon, which leads me to believe it is possible to overcharge my two batteries with out it. I am pretty conservitive with battery power though - so if you use a lot of power (or have three batteries like the Fiver) you probably could get away with out a controller.<br><br>http://www.icpglobal.com/html/pro15w.asp<br><br>
Old May 28, 2003 | 09:42 AM
pwabbott's Avatar
Re:RV batteries
I have noticed that Johnson Controls is the manufacturer of Deep Cycle Batteries of several major brand names as well as store brands. Some Store Brands are also manufactured by Johnson, ie. Wal-Mart, Costco. MCA for a Group 27 was rated 715 amps in one chain, 750 amps in another. Posted prices were almost the same, however one store required a trade-in or $6 core deposit. Also noticed Warranty period in the past year for many deep cycles has dropped from 36 months to 30 months. Guess too many are being stored for long periods of time without charge maintenance. We all lose when the average owner doesn't take care of their property while under warranty.<br> :'(
Stevie G
Mar 21, 2003 06:10 PM
DF5152
Mar 5, 2003 08:07 AM
Dieseldude4x4
Jan 4, 2003 03:07 PM
MCMLV
Nov 16, 2002 08:30 PM
Lary Ellis (Top)
Nov 2, 2002 01:07 PM
