Reverse lights....
Old Sep 30, 2007 | 01:03 AM
Got Mega?'s Avatar
Reverse lights....
With my trailer hooked up and the truck turned off the reverse lights stay on. Is this normal? I just bought the trailer.
Thx's
Old Sep 30, 2007 | 01:58 AM
mikelr's Avatar
Why would you think that could be normal???
Better look into the trailer wiring (new trailer end), constant 12V must be shorted to the reverse light curcuit.
This is assuming that you are refering to reverse lights on the trailer and not the truck.
Old Sep 30, 2007 | 09:34 AM
durasmack's Avatar
Dodge has the center pin on the trailer wire connection connected into the truck's reverse light circuit. It sounds like you have a short between the +12v wire on the trailer or in the plug and the wire for the center pin on the trailer plug (usually purple on 7 wire setup)
Old Sep 30, 2007 | 09:48 AM
Got Mega?'s Avatar
Sorry its the trucks reverse lights that stay on after the truck is turned off.
Old Sep 30, 2007 | 10:49 AM
darkvader's Avatar
if the truck reverse lights go off when you unhook the trailer plug it is the trailer wiring and/or ground. what truck?
Clark
Old Sep 30, 2007 | 10:54 AM
Got Mega?'s Avatar
2006 Mega Cab 2500 diesel. So where would you start?
Old Sep 30, 2007 | 11:39 AM
darkvader's Avatar
unplug the trailer. do they go off?
Clark
Old Sep 30, 2007 | 03:23 PM
durasmack's Avatar
It is in the trailer wiring. Take a continuity tester and see if there is a short between the center pin and the + 12 volt wire.
Here is diagram of the trailer plug.
Better yet, take the trailer side plug apart and disconnect the wire going to the center pin since you dont have backup lights on your trailer.
The diagram on the right is the trailer side. Left is the truck side.
Old Oct 2, 2007 | 09:40 PM
REF>Lancer's Avatar
Don't be too sure he does not have backup lights on the trailer,lots do now...
dsljunkie
14
Dec 27, 2018 02:14 PM
tntshrekuk
Jun 25, 2008 12:02 PM
CHarlan
Aug 6, 2003 08:40 PM
soundfetish
May 9, 2003 04:40 PM
