question regarding lp tank on motorhome
Old Jul 25, 2011 | 10:03 PM
kennyblatz's Avatar
i have a 1986 motor home and have not yet filled the LP tank. the guage reads full but im not sure it works correct. the tank says fill untill liquid appears. that is the 80% relief valve correct? now my question is it reads if in dought check manual bleed valve. am i checking for a liquid gas or a vapor gas when doing so? or both and if liquid comes out its over full?
thanks
Old Jul 26, 2011 | 10:19 AM
hubmonkey's Avatar
Okay I think I know what you are asking...
First off, is the valve handle triangle shaped? If it is then it has the 80% Shut Off valve (OPD) in it. You open the valve, start filling and then the bleeder screw on the left.. when the Vapor comes out you close the screw and close the valve and it is at capacity. This is on the 30lb ones.
Old Jul 26, 2011 | 04:03 PM
irocpractice's Avatar
thanks
Kenny,how big is the tank and,when was the last time the regulator was replaced?
DieselDodd
Dec 14, 2009 10:55 PM
zog
May 9, 2005 08:47 PM
CTDwannaB
Feb 23, 2005 08:10 PM
Beavermike
Jan 13, 2004 11:59 AM
Moparior
Nov 4, 2002 04:25 PM
