Pic of why you should check your stock trailer receiver hitch
Yikes! How much weight do you tow?
I have a classV reese and it did the same thing. I dont know what the po did tow but the hitch and the frame were both torn like that.
How'd you discover it, making noise? That looks like kind of a crappy hitch - thin steel at the bolting points.
Originally Posted by Ace
(Post 2427897)
I was carrying a 24' enclosed trailer w/ a lot of weight on the tongue and w/o a load distributing hitch. ~10k lbs total, but a lot up front. I discovered it just by looking... when I was hooking up the safety chains (plus i had read on this site to check the hitch). Replaced it with a monster class V...forgot the name brand, but it has 2 2" receivers and provisions for a truck campers rear tie downs. Though I'd post to remind others to check theirs. |
Originally Posted by macattack_ga
(Post 2428066)
...Replaced it with a monster class V..
I had that happen to my 97 3500 also. I can't even remember why I looked at it, just got luck I guess.
There is a fatory recall for that receiver failure.
too much tongue weight eh ? mine did that, welded it up with some gussets took care of it. I run adjustable shocks now too, to take out the heaving up and down motion when towing.
Originally Posted by CTD NUT
(Post 2428701)
What years does the recall cover?
I think it was 94-99. I *think* the 2000 trucks came standard with the 8 bolt receiver....but it may have been 01 - it has been awhile! It was the OEM 6 bolt receivers that were failing - they would all crack in the same place.
Better check mine next time I am out.
"There is a factory recall for that receiver failure."
Recall 00V107000 |
I just took the factory hitch off my 2000. It was a 6 bolt mount.
