No Gages, how much power?
Old May 24, 2010 | 10:02 PM
etn550's Avatar
I'm going to drive 12 hrs this weekend to possible buy a 31ft 6,500lb travel trailer. I have not yet installed gages and plan to but not before the trip.
I was going to set the Smarty to stock.
Should I set it lower than stock or just not worry about it. I'm going through the rolling mountains of I-81 all the way udown the appilachans from NY to TN. Will have plenty of long pulls on grade.
Old May 24, 2010 | 11:31 PM
CoastalDav's Avatar
You'll do just fine without the smarty. You'll be hooked up at 65mph at 2000 rpm's with the G56. The Cummins won't know its hooked to anything. The only tell tail will be fuel mileage, around 12-13 I'll bet.
Have a good trip, check them trailer tires before you leave with the tow and at least an hour later.
Old May 25, 2010 | 11:18 AM
rich's Avatar
yea you will be fine with out it but you will see less then 10 when towing
Old May 25, 2010 | 12:23 PM
FiverBob's Avatar
Just don't push it hard on the grades. Slow down and drop a gear if it acts like it would like to.
Bob
Haulin_in_Dixie
Jan 23, 2004 10:27 PM
dhe9
Oct 26, 2003 10:47 AM
jeffteel
Oct 14, 2003 09:48 PM
Haulin_in_Dixie
Mar 13, 2003 10:25 AM
taskE42
Mar 7, 2003 04:35 PM
