New Trailer!!!! Need help with weights.....
I just weighed my new LQ horse trailer empty. Need help seeing where I am at....
Truck Front axle: 4100 Rear axle: 6740 Trailer axles: 6980 Total weight: 17820 |
Your 10,840 lbs on the truck= well with in sticker on the door.
17,820 on first look is under GVW, on second look we would need to know if this is an empty weight or a loaded weight? If empty you will need revist scale once loaded to know exactly where your at. |
Originally Posted by T398
(Post 1155341)
17,820 on first look is under GVW, on second look we would need to know if this is an empty weight or a loaded weight? If empty you will need revist scale once loaded to know exactly where your at. From door sticker.. Front axle: 4740 Rear axle: 9350 GVWR: 11500 Is this both vehicle axles combined? What total trailer weight can I pull? |
What is the GVCWR for my truck?
Finally found what I was looking for on the dodge website.
Towing capacity= 15,900 lbs GCWR= 23000 lbs. I should be right at the limited all loaded up with about 500 lbs to spare. I got the curb weight front and rear and was able to calculate my pin weight from that. Pin weight= 2760. Trailer weight= 9740 (empty) Will be able to load it up another 6160 lbs. Correct me if I am wrong please. |
Looks like you got her figured out. Without going back to the scales loaded your as close as your going to get.
What brand LQ did ya pickup? T398 |
It is an Exiss Event XT412 with 12ft. short wall with the Sierra Blue Sky LQ. It is also 8ft wide / 7'6" tall. Little bit bigger than what I wanted but you know how wives want more room. I had some issues when I first got it but they have all been corrected under warranty. I know 4 Star makes some excellent trailers but no dealer anywhere near here so that was out.
