Load range for BF Goodrich tires
Old Nov 9, 2002 | 06:23 PM
bulthisl's Avatar
Re:Load range for BF Goodrich tires
Check your sidewalls<br>BFG's have a 3 ply sidewall , most others do not.<br>I run 285/75/16 BFG's and they run great with a load<br>I load my truck regularly.<br><br> : Eddie : 8)
Old Nov 10, 2002 | 06:18 PM
Wilber1's Avatar
The 265/75/16 E rated Michelins that came stock on my 2001 2500 SWB are rated at 3415 lb at 80 psi for SW and 3000 lb at 80 psi for duals. Towing a 10,000lb 5er, with 70 - 80 psi in the rears, stability is excellent and I will use the same tires when these need replacing.<br><br>Nick
Old Nov 11, 2002 | 03:10 AM
Haulin_in_Dixie's Avatar
Curous, my '99 came with 245/75 16E, I am currently running the spare on my trailer. Impressive tread and wear.
Old Nov 11, 2002 | 10:28 AM
KC's Avatar
KC
[quote author=Big dawg link=board=11;threadid=6717;start=0#63270 date=1036644790]<br>Okay, everyone I've asked about tires say I've have to have (or should have) an &quot;E&quot; rated tire in order to haul my 5er around (12,500lbs) :. The stock tires I have do have an &quot;E&quot; rating at around 3000 lbs (or close to that). I was looking at the BF Goodrich tires site and they have a BF Goodrich AT (LT295/75R16D) It's weight rating is at 3414@65 psi. Question is it's a &quot;D&quot; rated tire but rated at a higher level than my stock &quot;E&quot; rated tires. Will this tire work or should I say with the &quot;E&quot; rated tires ??? <br>Thanks for any input...Big dawg<br>[/quote]<br><br>Another point to make is the 295s are larger tires, are you going to be towing a 5th wheel, in a stock size you should keep with your &quot;E&quot; range tires to get the proper load.<br><br>KC
Firstgenfanatic
Apr 10, 2008 12:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
PowerstrokeThis
Feb 8, 2005 10:39 PM
erics76
Jul 29, 2003 06:50 PM
Bryan
Nov 24, 2002 10:23 PM
