Kore HP or Leveling kit with Truck Camper
I've got an 06 SB 2500 Auto pretty much stock. I carry a 2k lbs truck camper and tow and enclosed snowmobile trailer. Everybody in the RV world says buy rancho 9000xl. I want to upgrade my wheels/tires to 20's and 35's so i will at the least need a leveling kit. I've read a lot of good things about the Kore HP kit. Any feedback with Kore and a Truck camper? I do very little off-roading, just need to get back enough to unload the dirtbike.
I'm curious about this as well. Are you planning just the springs up front, or will you be adding the springs in the back as well? Also the camper, have you had a chance to weigh your setup to see what your actual weights are?
No I haven't weighed the camper but I pretty confident I am close. Wet weight I am guessing below 2,500 lbs
I think you'd be okay front wise and I think even in the rear, I don't think the spring pack is supposed to reduce your load any. With the rear you may be too high for normal air bags if your looking into those. You may have to do the Carli air bags which are good but more coin.
Josh
Josh
DodgeTruckRam
49
Apr 2, 2009 09:42 AM
erik_herrling
Jun 15, 2007 01:09 AM
bogie418
Jan 15, 2007 12:32 PM
Hammer Down
May 25, 2006 06:09 PM
EricK
Apr 15, 2005 04:34 PM
